I'm running a VM on an ESXI with XL710(i40en) card On SR-IOV mode.
I'm running DPDK 21.11 using iavf driver in the VM.
The VF is configured with 4 queues.
I'm able to observe that the RSS is not working and all the traffic is directed towards a
single queue.
The driver version on the ESXI host.
Driver Info:
Bus Info: 0000:d8:00:1
Driver: i40en
Firmware Version: 6.80 0x800042e3 0.385.97
Version: 2.4.1.0
ESXI version : 7.0.1
This works fine if we use i40evf driver VF(DPDK19) on the VM side and there is a significant drop when we upgrade to iavf(DPDK21).
I am setting mq_mode to
port_conf.rxmode.mq_mode = RTE_ETH_MQ_RX_RSS;
port_conf.rx_adv_conf.rss_conf.rss_hf = IAVF_RSS_OFFLOAD_ALL
Hello Mr Kishan,
Good day ~
Thank you for posting Ethernet Community. I'm here to follow up case as per subject. Appreciate you can follow below Support with
DPDK https://www.dpdk.org/ kindly refer or open an Intel Premier Support case at https://www.intel.com/content/www/us/en/secure/forms/intel-premier-support/enrollment.html (Required Login/Create new account)
If you wish to support thru community case you may refer to the link below as well
https://community.intel.com/t5/Embedded-Connectivity/bd-p/embedded-networking-connectivity
For further concern please do let us know.
Thank you & Best Regards,
Devi_ Intel
Greeting Kishansimha,
Regarding your case, we are following up to find out if you were able to complete the actions we previously recommended.
Please reply to this thread to confirm, so we can continue helping with a resolution. Looking forward to receiving your reply
Devi_ Intel
