Ethernet Products
4855 Discussions
RXDCTL.ENABLE register could not set on I210 Card
anilkaradag
I use a custom network driver for Intel I210 card. Card initialization is different than general purpose drivers(i.e. igb) due to we need to faster. The card can be initialized and used by OS in legacy BIOS; but RXDCTL/TXDCTL bits could not be enabled on UEFI BIOS.
p.s.: when network stack is enabled in UEFI BIOS; the mentioned bits are set properly by the custom driver.
Does anyone know that why?
Caguicla_Intel
Hello anilkaradag,
Can you share where did you get the custom network driver for Intel I210 card? Are you designing/programming your own driver for the I210? Is the I210 a discrete LAN card or is it embedded on the motherboard?
We look forward to your response.
In case we don’t hear from you, we’ll follow up after 3 business days.
Crisselle C
Intel® Customer Support
anilkaradag
We use onboard card; yeap the using driver has been developed by design team in the long time ago. I found a patch for e1000 driver for giving support of I210 card. Why rxdct/rtxdct bits writing request rejected? which operation is mandatory before that?
[1] https://lists.denx.de/pipermail/u-boot/2014-August/185859.html
Caguicla_Intel
Hello anilkaradag,
Thank you for the prompt reply.
Please allow us to check on this. We will get back to you within 1-3 business days.
Hoping for your patience.
Crisselle C
Caguicla_Intel
Hello anilkaradag,
Thank you for the patience on this matter.
After checking, we regret to inform you that we do not support u-boot.
Let us know if you have additional questions and clarifications.
Looking froward to your reply.
In case we don't hear from you, we'll follow up after 3 business days.
Crisselle C
anilkaradag
Thank you for this return. But i need help and could you please say how can i get? Which team is responsible/an expert about the topic?
anilkaradag
In addition i dont use u-boot for installation OS on uefi bios. My actual question is which steps must be done before set RXDCTL/TXDCTL bits? Why my writing request are rejected?
Caguicla_Intel
Hello anilkaradag,
Thank you for the reply.
Please allow us to check on this further. We will get back to you within 2-3 business days.
Crisselle C
Caguicla_Intel
Hello anilkaradag,
Good day!
We have sent you a personal message to gather some personal information, kindly check your inbox.
We look forward to your reply.
Crisselle C
Caguicla_Intel
Hello anilkaradag,
How are you today?
We'd like to check if you have received our personal message 5 days ago. In case you don't, please let us know so we can re-send it to you.
Awaiting to your response.
Crisselle C
Caguicla_Intel
Hello anilkaradag,
Please be informed that we will now close this request since we haven't received any response from our previous follow ups. Should you have any other concerns or assistance needed in the future, feel free to post a new question.
May you have a lovely day ahead!
Crisselle C
