Ethernet Products
5505 Discussions
Re: Obtaining EEUPDATE utility
dpst76
Anybody know where on this site I can download EEUPDATE software?   I can not find this anywhere even with an account.     Note I have an ASUS Q87-M Board there are 2 types that use the same bios, original problem is board has X2 nics both I211 & I217-LM.  When clear and fresh re-flash the bios with external flasher I can get I211 nic working but no go after rebooting both nics take on the properties of I217-LM nics and come up with error code 10 in Windows (No longer working).
After looking around in multiple forms it appears that when a driver was being upgraded. etc via Windows or intel an error must have occured causing the system to overwrite the properties causing the error.  So at this time only means of correcting would be to try and re-flash the nics & maybe setting a mac on the ports.
If anyone else has seen this error and have corrected, would like some feed back.   As it stands looking for the software to try an work on this.
Sreelakshmi1
Hi dpst76,
Greetings!
Thank you for posting in Intel community forum!
We understand that you are looking for EEUPDATE tool for your network interface. The EEUPDATE tool can be found in the Intel Resource & Design Center (RDC) privileged account on the following website:
https://www.intel.com/content/www/us/en/resources-documentation/developer.html#gs.kly924
Kindly note the tool require NDA access. For further details, please refer to the article:
https://www.intel.com/content/www/us/en/support/articles/000058073/programs/resource-and-documentation-center.html
Regarding the NIC issue with error code 10 in Windows (No longer working), kindly check with ASUS (Original Equipment Manufacturer) for further assistance, as the NICs are pre-installed in the ASUS Q87-M Board.
Thank you for understanding.
Sreelakshmi
