Ethernet Products
5343 Discussions
Re: Why log message printed "e1000e 0000:0f:00.0: eth2: Reset adapter unexpectedly"
耀耀葵_李
Hi Wb,
No more inquiry about this! But i got another one problem!
Please help me check what should i do to solve it!
Mar 13 10:01:05 localhost-0 kernel: igb 0000:05:00.0: Detected Tx Unit Hang
Mar 13 10:01:05 localhost-0 kernel: Tx Queue <0>
Mar 13 10:01:05 localhost-0 kernel: TDH <3>
Mar 13 10:01:05 localhost-0 kernel: TDT <3>
Mar 13 10:01:05 localhost-0 kernel: next_to_use <3>
Mar 13 10:01:05 localhost-0 kernel: next_to_clean <1>
Mar 13 10:01:05 localhost-0 kernel: buffer_info[next_to_clean]
Mar 13 10:01:05 localhost-0 kernel: time_stamp <1071ac597>
Mar 13 10:01:05 localhost-0 kernel: next_to_watch
Mar 13 10:01:05 localhost-0 kernel: jiffies <1071acff6>
Mar 13 10:01:05 localhost-0 kernel: desc.status <0>
Mar 13 10:01:07 localhost-0 kernel: igb 0000:05:00.0: Detected Tx Unit Hang
Mar 13 10:01:07 localhost-0 kernel: Tx Queue <0>
Mar 13 10:01:07 localhost-0 kernel: TDH <3>
Mar 13 10:01:07 localhost-0 kernel: TDT <3>
Mar 13 10:01:07 localhost-0 kernel: next_to_use <3>
Mar 13 10:01:07 localhost-0 kernel: next_to_clean <1>
Mar 13 10:01:07 localhost-0 kernel: buffer_info[next_to_clean]
Mar 13 10:01:07 localhost-0 kernel: time_stamp <1071ac597>
Mar 13 10:01:07 localhost-0 kernel: next_to_watch
Mar 13 10:01:07 localhost-0 kernel: jiffies <1071ad7c6>
Mar 13 10:01:07 localhost-0 kernel: desc.status <0>
Mar 13 10:01:09 localhost-0 kernel: igb 0000:05:00.0: Detected Tx Unit Hang
Mar 13 10:01:09 localhost-0 kernel: Tx Queue <0>
Mar 13 10:01:09 localhost-0 kernel: TDH <3>
Mar 13 10:01:09 localhost-0 kernel: TDT <3>
Mar 13 10:01:09 localhost-0 kernel: next_to_use <3>
Mar 13 10:01:09 localhost-0 kernel: next_to_clean <1>
Mar 13 10:01:09 localhost-0 kernel: buffer_info[next_to_clean]
Mar 13 10:01:09 localhost-0 kernel: time_stamp <1071ac597>
Mar 13 10:01:09 localhost-0 kernel: next_to_watch
Mar 13 10:01:09 localhost-0 kernel: jiffies <1071adf96>
Mar 13 10:01:09 localhost-0 kernel: desc.status <0>
Mar 13 10:01:10 localhost-0 kernel: bonding: bond0: link status definitely down for interface slot0_GE4, disabling it
Mar 13 10:01:13 localhost-0 kernel: igb 0000:07:00.0: Detected Tx Unit Hang
Mar 13 10:01:13 localhost-0 kernel: Tx Queue <0>
Mar 13 10:01:13 localhost-0 kernel: TDH <1>
Mar 13 10:01:13 localhost-0 kernel: TDT <1>
Mar 13 10:01:13 localhost-0 kernel: next_to_use <1>
Mar 13 10:01:13 localhost-0 kernel: next_to_clean <0>
Mar 13 10:01:13 localhost-0 kernel: buffer_info[next_to_clean]
Mar 13 10:01:13 localhost-0 kernel: time_stamp <1071ae524>
Mar 13 10:01:13 localhost-0 kernel: next_to_watch
Mar 13 10:01:13 localhost-0 kernel: jiffies <1071aef36>
Mar 13 10:01:13 localhost-0 kernel: desc.status <3c>
Mar 13 10:01:13 localhost-0 kernel: igb 0000:05:00.0: slot0_GE4: igb: slot0_GE4 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: None
Mar 13 10:01:13 localhost-0 kernel: bond0: link status definitely up for interface slot0_GE4, 1000 Mbps full duplex.
Mar 13 10:01:15 localhost-0 kernel: igb 0000:07:00.0: Detected Tx Unit Hang
Mar 13 10:01:15 localhost-0 kernel: Tx Queue <0>
Mar 13 10:01:15 localhost-0 kernel: TDH <1>
Mar 13 10:01:15 localhost-0 kernel: TDT <1>
Mar 13 10:01:15 localhost-0 kernel: next_to_use <1>
Mar 13 10:01:15 localhost-0 kernel: next_to_clean <0>
Mar 13 10:01:15 localhost-0 kernel: buffer_info[next_to_clean]
Mar 13 10:01:15 localhost-0 kernel: time_stamp <1071ae524>
Mar 13 10:01:15 localhost-0 kernel: next_to_watch
Mar 13 10:01:15 localhost-0 kernel: jiffies <1071af706>
Mar 13 10:01:15 localhost-0 kernel: desc.status <3c>
Mar 13 10:01:16 localhost-0 kernel: bonding: bond0: link status definitely down for interface slot0_GE2, disabling it
st4
New Contributor III
Hi yk.lee,
Thank you. I can see there is the TX hang error and link status down , can you share more information and more description about the environment and the problem
-What is the exact NIC model?
-What is the Linux version?
-Driver version
-What is the brand and model of the switch?
Rgds
wb
Hi Yk.lee,
Please feel free to provide the information. Thanks.
rgds,
wb
