Ethernet Products
5821 Discussions
Re: i210IS with SGMII PHY (the DP83867)
Venkat_M
Hi Carlos,
The above design is similar to our's.. Our Design has used I210IS for SGMII output, The SGMII is fed to an external PHY DP83867CS (TI Make). We are trying to flash Dev_Start_I210_Sgmii_NCSI_8Mb_A2.bin file into the EEPROM, But we are not able to establish a link. Please Guide us what to be done.
Your help would be highly appreciated.
Venkat.
Fikri_Intel
Hi Venkat_M,
Thank you for contacting Intel.
We appreciate you reaching out to us regarding the reported issue. For your inquiry regarding the Intel® I210, you may refer to the following resources:
1- I210 Datasheet including details on the SGMII interface and EEPROM configuration:
https://cdrdv2.intel.com/v1/dl/getcontent/333016
2- Configuration Scenarios and Differences Between I210 Variants:
https://www.intel.com/content/www/us/en/content-details/332763/intel-ethernet-controller-i210-specification-update.html
These documents should provide the necessary technical insights into the configuration and supported interfaces.
If further assistance is needed, particularly for advanced configuration or integration support, we kindly recommend opening a case via the Intel Premier Support (IPS) portal if you have an active IPS account.
https://www.intel.com/content/www/us/en/support/articles/000057045/ethernet-products.html
Fikri O.
