Ethernet Products
4528 Discussions
Red Rock Canyon - EPL Verification Test
YBadi
Hello to ALL,
I want to measure EPL RefClk for RRC,
According to the datasheet , "As a guideline, total phase jitter of the clock source should be less than 0.25 ps RMS"
i have some questions:
1) What is total phase jitter (RMS) ? is it "Random Jitter"? is it measure with Scope or Spectrum (like phase noise)?
2) How much bandwidth is enough to measure this clock?
thanks,
Yuval.
Hi Yuval,
Just to double check, are you referring to the product below? Please provide the model
https://ark.intel.com/products/codename/63546/Red-Rock-Canyon
wb
Hi Yuval,
wb
YBadi
I talking about FM10840,
Actually the quote was from datasheet of FM10000, that belongs to the 2 projects that you linked above.
Can you also tell me if there is a difference between FM10840 & FM10420 about this requirement?
Yuval.
Hi Yuval,
Thank you for the clarification. I am not an expert on these products, but here is what I found regarding comparison of FM10840 and FM10420
http://ark.intel.com/m/compare/92674,92675
I will need to further check your two inquiries about the FM10840.
wb
