Ethernet Products
5607 Discussions
Regarding Packet Loss before and after PFC Configuration in RDMA.
Sushrut
We have successfully configured RDMA and PFC using Intel Ethernet Network Adapter E810-XXVDA2/E810-CQDA2.
We wanted to know if there is any method/technique/tool by which we can check packet loss before and after PFC Configuration.
Thanking you in anticipation.
Sushrut Bhokre
Mike_Intel
Hello Sushrut,
Before we proceed, let me clarify if you are designing a board/system with embedded E810-XXVDA2/E810-CQDA2?
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
Intel® Customer Support
Sushrut
Hi Mike,
No, we are not designing a board/system with embedded E810-XXVDA2/E810-CQDA2, we are just using it for the benchmarking purpose and we want to have an idea on the packet loss in RDMA configuration with/without using PFC.
So, if you have any method/technique/tool by which we can check the packet loss, it would be helpful.
Sushrut Bhokre
Mike_Intel
Hello Sushrut,
Thank you for the quick reply. For us to further check the issue, please provide the following details.
  1. Can you tell us how you are conducting the bencmark?
  2. Are you using PCIe E810-XXVDA2/E810-CQDA2?
  3. What is the brand and model of your board/system?
  4. Can you tell us more about the system that you are using like OS and link of the driver used for us to get a better picture of your configuration for benchmarking.
Michael L.
Sushrut
Hi Mike,
1. We are performing fio test to benchmark the performance.
2. Yes we are using E810-XXVDA2/E810-CQDA2.
3. We are using Intel Server Board S2600WF and Intel Server Board S2600BP.
4. Operating System: Red Hat Enterprise Linux release 8.6 (Ootpa) Kernel:-Linux 4.18.0-372.16.1.el8_6.x86_64 GNU/Linux.
We are using Intel Network Adapter Driver for E810 Series Devices under Linux
ice version ice-1.8.9
https://www.intel.in/content/www/in/en/download/19630/intel-network-adapter-driver-for-e810-series-devices-under-linux.html
We are using Linux RDMA Driver for the E810 and X722 Intel Ethernet Controllers
irdma-1.8.46
https://www.intel.com/content/www/us/en/download/19632/linux-rdma-driver-for-the-e810-and-x722-intel-ethernet-controllers.html
We have completed the benchmarking using fio. We are unable to check the packet loss with and without PFC. It would be really great if you can help us with the same.
Sushrut Bhokre
Sushrut
Hi Mike,
2. Yes we are using E810-XXVDA2 and E810-CQDA2.(Both)
irdma-1.8.46
Sushrut Bhokre
Sushrut
Hi Mike,
irdma-1.8.46
Sushrut Bhokre
Sakshi_Saraf
Hi Mike,
irdma-1.8.46
Sakshi Saraf
Sakshi_Saraf
Hi Mike,
irdma-1.8.46
Sakshi Saraf
Mike_Intel
Hello Sushrut,
I hope you're having a wonderful day. I am just making a follow up on the information that we requested for us to further check this inquiry.
Michael L.
Sushrut
Hi Mike,
irdma-1.8.46
Sushrut Bhokre
Sakshi_Saraf
Hi Mike,
irdma-1.8.46
Sakshi Saraf
Mike_Intel
Hello Sushrut,
Thank you for providing the details that we requested. I will have this checked by our Engineers and while doing that, please help generate the SSU logs of your system for further analysis. Kindly download the utility here:
https://www.intel.com/content/www/us/en/download/18895/intel-system-support-utility-for-the-linux-operating-system.html?wapkw=ssu
Michael L.
Sushrut
Hi Mike,
We generated the SSU logs for our system using the utility provided.
PFA the logs for the same.
Sushrut Bhokre
Mike_Intel
Hello Sushrut,
Thank you for the quick reply. We need to further check these details so that we can provide some recommendations. Please give us 2 to 3 working days to provide an update.
Thank you and stay safe.
Michael L.
Mike_Intel
Hello Sushrut,
Thank you for patiently waiting for our update. Upon checking your inquiry, you already have an existing case 05546299 which is being handled by your local support group. The contact person in that case is from Zoho Corp as well. The concern was already answered by your local group also. Because of this, we recommend that you use case number 05546299 moving forward and to avoid confusion. As for this thread and case, we will close this one now. If you need assistance again in the future, please post a new question.
Michael L.
