Ethernet Products
5614 Discussions
Release of 10GB Ethernet drivers for Windows Server 2016
MMarc24
now that Windows Server 2016 is in general availability, when can we expect to have a stable driver release for Windows Server 2016? The TP5 beta drivers are not very stable.
thanks!
Hi Magenois,
Thank you for the post. I will check for the release date and update you once there is the feedback. Thank you.
rgds,
wb
Ml3
Hi
I also need these ASAP, will these drivers also contain the teaming software that's been missing, I need to update a clustered server that has two X520 adapters in a NIC team?
Hi Magenois,
Good day. Have you tried using the driver version 21.1 already?
https://downloadcenter.intel.com/download/26092/Intel-Network-Adapter-Driver-for-Windows-Server-2016
Hope this help.
rgds,
wb
MMarc24
Hello
Yes I tried them. Somehow they dont want to install for my X552. The installer says that there was not Intel adapter detected. So I am still running the drivers provided with win2016 out of the box.
Hi Magenois,
Thank you for the update. Checking on the website, I am sorry to inform you X552 is not supported in Windows 2016.
rgds
wb
MMarc24
This blog post seems to say otherwise:
Hi Magenois,
Let me check on this, thanks for sharing the information.
rgds,
wb
Ml3
Hi wb
Any news on why I cant get the latest drivers to work with the X520?
Mark
Hi Mark,
You can download the 21.1 CD for the drivers of X520 and X552 at link below.
https://downloadcenter.intel.com/download/22283/Intel-Ethernet-Adapters-Connections-CD
Hope this helps.
rgds,
wb
Ml3
Thanks wb that works getting the Windows Server 2016 driver installed however it still doesn't give back the Teaming option! When is teaming coming back? This is important as these NICs are set up as failover on the current Windows 2012 R2 servers and this functionality is still required when we upgrade them to 2016
Mark
Hi Mark,
Thank you for the update, let me further check for you.
rgds,
wb
Ml3
Any news on the teaming wb?
Mark
HI Mark,
I am sorry I have not received the updates yet. I will let you know once there is any progress.
rgds,
wb
Ml3
Any news on the teaming? I really need an answer on this?
Mark
Hi Mark,
Thanks for the info. Here is the website you can refer to teaming in Windows* 2016.
http://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000022706.html
Hope the above helps.
rgds,
wb
Ml3
Thanks wb
I can confirm these Intel drivers work now and are teamed using the Microsoft Teaming software as per the quoted article.
I am happy for you to mark this as answered although I am not the OP
Thanks for your help
Mark
Hi Mark,
You are welcome, glad to be of help.
rgds,
wb
Ml3
wb
The 21.1 drivers don't support the X520 DA however the beta ones for Windows Server 2016 Tech Preview 5 did so what's gping on here?
Mark
Hi Mark,
Thank you for bringing this to our attention. let me further check on this.
rgds
wb
