Ethernet Products
4874 Discussions
SCCM and i219-LM network driver
aahme21
Dear All,
I am trying to import the network driver of EliteDesk 800 G2 to our SCCM . the driver should be intel I219 LM but it shows in sccm after the importing as Intel I217-lm so when i PXE the machine it reach to the networking section and fail to continue the PXE .
Please note that i use winpe 3 , windows 7 x64 enterprise , latest drive from both Intel and HP
Hi ahmedg149,
Thank you for contacting Intel.
Do you have the filename of the driver that you tried to import?
Sincerely,
Sandy
aahme21
Hi ahmedg149,
Thank you for your information.
Upon checking our drivers, only e1d62x64 contains driver for the Intel(R) Ethernet Connection I219-LM. Anyway, I will attach both drivers so you may try our driver version.
In case you still encounter same issue with our driver, please report the issue to HP* so they can help test the drivers.
Sincerely,
Sandy
Hi ahmedg149,
Good day.
I would like to check if you were able to deploy image to your systems. Hope you are able to fix the issue at the soonest.
Sincerely,
Sandy
aahme21
Hi Sandy,
I managed to sort out the issue by re-create a new WIM file for SCCM and import the NIC driver Intel(R) Ethernet Connection I217-LM version 12.13.17.7.
Sorry for the late response
Hi ahmedg149,
Good day. Thank you for your reply and sharing your test results with us.
Feel free to contact us again if you need our assistance in the future.
Sincerely,
Sandy
