Ethernet Products
5821 Discussions
SFT teaming probe issue
HDuri
I'm using Windows 7 embeded and SFT teaming on 2 adapters.
On this teaming, 3 VLANs are created.
I want to garantie my path so I configure the connection monitoring to probe one of my network equipement.
I ran Wireshark to analyze this traffic and here are some interresting points I saw :
- If I enter the management IP of one of the Cisco switch, no answer.
- If I probe a Ubunter server, no answer
- If I probe a Windows server (or desktop) it's OK
Furthermore with Wireshark (1.8.4) the frames sent by the driver are seen as "Ethernet Frame check sequence incorrect" and look like that :
Sender MAC address: Bull_38:67:b0 (08:00:38:38:67:b0)
Sender IP address: 0.0.0.0 (0.0.0.0)
Target MAC address: 00:00:00_00:00:00 (00:00:00:00:00:00)
Target IP address: 10.24.5.254 (10.24.5.254)
I saw that some equipments doesn't answer because the frame has no IP source so I want to know if there is any trick to specify the IP source (regedit, config file etc.) ?
