Ethernet Products
4631 Discussions
SR-IOV Virtual function not working ( no /sys/class/net/IFNAME/device/sriov_numvfs ) , but direct pci passthrough works fine
fYama
Hi
I Have some servers with both X710 and 82599ES
I can use 82599ES perfectly, ( both pci and virtual )
But on X710 card, I can only use full pci passthrough
There is no /sys/class/net/IFNAME/device/sriov_numvfs
Here is my lspci
43:00.1 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 01)
Subsystem: Intel Corporation Ethernet Converged Network Adapter X710
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 45
Region 0: Memory at f7000000 (64-bit, prefetchable) [size=16M]
Region 3: Memory at f5ff8000 (64-bit, prefetchable) [size=32K]
Expansion ROM at fb180000 [disabled] [size=512K]
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=1 PME-
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Address: 0000000000000000 Data: 0000
Masking: 00000000 Pending: 00000000
Capabilities: [70] MSI-X: Enable+ Count=129 Masked-
Vector table: BAR=3 offset=00000000
PBA: BAR=3 offset=00001000
Capabilities: [a0] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 2048 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0.000W
DevCtl: Report errors: Correctable- Non-Fatal+ Fatal+ Unsupported+
RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop- FLReset-
MaxPayload 256 bytes, MaxReadReq 512 bytes
DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr- TransPend-
LnkCap: Port #0, Speed 8GT/s, Width x8, ASPM L1, Exit Latency L0s <2us, L1 <16us
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 5GT/s, Width x8, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR-, OBFF Not Supported
DevCtl2: Completion Timeout: 65ms to 210ms, TimeoutDis-, LTR-, OBFF Disabled
LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [e0] Vital Product Data
Product Name: X710 10GbE Controller
Read-only fields:
[V0] Vendor specific: FFV18.0.17
[PN] Part number: 5N7Y5
[MN] Manufacture ID: 31 30 32 38
[V1] Vendor specific: DSV1028VPDR.VER2.0
[V3] Vendor specific: DTINIC
[V4] Vendor specific: DCM1001FFFFFF2101FFFFFF1202FFFFFF2302FFFFFF1403FFFFFF2503FFFFFF1604FFFFFF2704FFFFFF1805FFFFFF2905FFFFFF1A06FFFFFF2B06FFFFFF1C07FFFFFF2D07FFFFFF1E08FFFFFF2F08FFFFFF
[V5] Vendor specific: NPY2
[V6] Vendor specific: PMT7
[V7] Vendor specific: NMVIntel Corp
[V8] Vendor specific: L1D0
[RV] Reserved: checksum good, 1 byte(s) reserved
Read/write fields:
[Y1] System specific: CCF1
End
Capabilities: [100 v2] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt+ UnxCmplt+ RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP+ FCP+ CmpltTO+ CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC+ UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
CEMsk: RxErr+ BadTLP+ BadDLLP+ Rollover+ Timeout+ NonFatalErr+
AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
Capabilities: [140 v1] Device Serial Number 40-5b-2d-ff-ff-fe-fd-3c
Capabilities: [150 v1] Alternative Routing-ID Interpretation (ARI)
ARICap: MFVC- ACS-, Next Function: 0
ARICtl: MFVC- ACS-, Function Group: 0
Capabilities: [1a0 v1] Transaction Processing Hints
Device specific mode supported
No steering table available
Capabilities: [1b0 v1] Access Control Services
ACSCap: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
ACSCtl: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
Kernel driver in use: i40e
Kernel modules: i40e
Daniel_D_Intel1
Hello FYama, Thank you for posting in Intel Ethernet Communities. Please provide the markings from the product label so we can identify the adapter. Please provide "ethtool -i <interface>" and "ethtool -k <interface>". Please also provide "ethtool -i <interface>" from the VM. Let us know if you have any other questions. Best regards, Daniel D Intel Customer Support Under Contract to Intel Corporation
fYama
Hi
Here it is:
# ethtool -i enp67s0f1
driver: i40e
version: 2.1.14-k
firmware-version: 5.40 0x80002d35 18.0.17
expansion-rom-version:
bus-info: 0000:43:00.1
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
# ethtool -k enp67s0f1
Features for enp67s0f1:
rx-checksumming: on
tx-checksumming: on
tx-checksum-ipv4: on
tx-checksum-ip-generic: off [fixed]
tx-checksum-ipv6: on
tx-checksum-fcoe-crc: off [fixed]
tx-checksum-sctp: on
scatter-gather: on
tx-scatter-gather: on
tx-scatter-gather-fraglist: off [fixed]
tcp-segmentation-offload: on
tx-tcp-segmentation: on
tx-tcp-ecn-segmentation: on
tx-tcp-mangleid-segmentation: off
tx-tcp6-segmentation: on
udp-fragmentation-offload: off
generic-segmentation-offload: on
generic-receive-offload: on
large-receive-offload: off [fixed]
rx-vlan-offload: on
tx-vlan-offload: on
ntuple-filters: off
receive-hashing: on
highdma: on
rx-vlan-filter: on [fixed]
vlan-challenged: off [fixed]
tx-lockless: off [fixed]
netns-local: off [fixed]
tx-gso-robust: off [fixed]
tx-fcoe-segmentation: off [fixed]
tx-gre-segmentation: on
tx-gre-csum-segmentation: on
tx-ipxip4-segmentation: off [fixed]
tx-ipxip6-segmentation: off [fixed]
tx-udp_tnl-segmentation: on
tx-udp_tnl-csum-segmentation: on
tx-gso-partial: on
tx-sctp-segmentation: off [fixed]
tx-esp-segmentation: off [fixed]
fcoe-mtu: off [fixed]
tx-nocache-copy: off
loopback: off [fixed]
rx-fcs: off [fixed]
rx-all: off [fixed]
tx-vlan-stag-hw-insert: off [fixed]
rx-vlan-stag-hw-parse: off [fixed]
rx-vlan-stag-filter: off [fixed]
l2-fwd-offload: off [fixed]
hw-tc-offload: off
esp-hw-offload: off [fixed]
esp-tx-csum-hw-offload: off [fixed]
rx-udp_tunnel-port-offload: on
Daniel_D_Intel1
Hello FYama, Thank you for the reply. Have you only tried the in-kernel version of the driver, or have you tried the latest i40e? Are you using KVM, and are you using a virtual API, or hardware emulator? What does the VF do when SR-IOV is enabled? Is there a VF driver on the VM? Please check with the OEM if there is a firmware update, as this appears to be a non-retail Intel version of the adapter. Let us know if you have any questions. Best regards, Daniel D Intel Customer Support Under Contract to Intel Corporation
Daniel_D_Intel1
Hello FYama, Please let us know if a firmware update from the OEM helped you solve this issue. If you have any other questions please let us know. Best regards, Daniel D Intel Customer Support Under Contract to Intel Corporation
VincentT_Intel
Hi FYama, Please let us know if there's other assistance needed. Best Regards, Vince T. Intel Customer Support Under Contract to Intel Corporation
