Ethernet Products
5743 Discussions
SR-IOV and port trunking
sfrid
Hey all,
In my setup I have 2 PFs that on each of them I defined a single VF (p1p1 with VF 0 and p1p2 with VF 0).
I have a VM which I attached with these two VFs, and on my VM I defined these two ports as trunk group.
Problem is that when arp request is sent from my VM via one of the VF and comes back via the other VF it is dropped because MAC address does not match.
My question is - does SR-IOV support port trunking? How should it be configured?
Shaham
st4
New Contributor III
HI Shahamf,
Thank you for the post. Can you help alos by providing what is the network adapter model used here? And the operating system?
I will further check for you. Thanks.
rgds,
wb
sfrid
Hey Wb,
Network adapter model is Intel 82599 10 Gigabit NIC, OS is both Centos 7 & Ubuntu 14.04.
Shaham
st4
New Contributor III
Hi Shahamf,
Thank you for the info. Would you help clarify which OS is the host OS and the guest OS? What are the kernel versions?
For the Intel 82599 10 Gigabit NIC, is it an onboard NIC or X520 series network adapter? Please refer to this site for the model. http://ark.intel.com/compare/39776,41164,68672 ARK | Compare Intel® Products
wb
