Hello, I need your help!
The network card Intel 82599ES da 2 and server CISCO UCS C220 - all with support sr-iov. I have successfully turned on and implemented the sr-iov, and the guest os works fine with it. But sr-iov does not want to work with the QinQ.I was installed latest driver for Intel 82599ES da2 - "ixgbevf-4.5.1". On the vSwitch I was turned off: Promiscuous Mode, MAC Address Change and Forged Transmit but its not help.
Esxi 6.5 logs constantly writes the following when QinQ is enabled:
2018-12-25T16: 24: 10.849Z cpu43: 66164) <4> ixgbe 0000: 06: 00.0: vmnic0: 1 Spoofed packets detected
2018-12-25T00: 00: 34.491Z cpu10: 66044) <4> ixgbe 0000: 06: 00.0: vmnic0: MACVLANs not supported
Hi, thank you for your answer. Is qinq support planned for the future? and why now there is no support for qinq ? this is a very important thing now...
Hi
what Intel NIC card does support 802.1ad,SR-IOV and preferrably vxlan on Vpshere ( not linux)
thanks in advance for your response
