Ethernet Products
4364 Discussions
SR-IOV dropping packets when *other* VFs are configured
KMill11
I've been doing some testing using an HP Ethernet 1Gb 2p 361T Adapter in a DL380p Gen8. The software used is CentOS 6.4 and igb 4.3.0 and igbvf 2.3.2 Intel drivers. I've noticed that when a VF NIC is under load (typically reading multicast at 80-110 MB/s), the packets can get dropped when one or more of the following are performed against different VFs on the same card:
  • ethtool -G
  • vconfig
  • ip link set up dev eth1.NNN
  • python sock.setsockopt(socket.IPPROTO_IP, socket.IP_ADD_MEMBERSHIP,mreq) call
Is this to be expected?
Thanks in advance,
== k+ ==
