Ethernet Products
Schema
Bonjour,
Je souhait avoir le schema ou la carte ( Orcad ex.) pour WGi218LM.
Cordialement, merci.
VincentT_T_Intel
Hi WGi218LM, sharing the link on where you can find the datasheet of i218-LM ethernet controller, this document contains block diagram.
https://www-ssl.intel.com/content/www/us/en/ethernet-controllers/ethernet-connection-i218-gbe-datasheet.html Intel® Ethernet Connection I218: Datasheet
hope this help.
regards,
vince
Ok, thans very much.
Best regard.
