Ethernet Products
5821 Discussions
Setting Intel X520-2 NIC to iSCSI using BOOTUTILW64E
AAnth4
I recently installed an Intel X520-2 NIC to my windows server. Windows auto-installed it and I can access the device. It is currently working as just a regular ethernet adapter. I need to change it to iSCSI mode. I did some research and found that I need to use the Intel Ethernet Flash Firmware Utility. Here is what I am currently doing:
C:\Intel21.1\APPS\BootUtil\Winx64>BOOTUTILW64E.EXE
Intel(R) Ethernet Flash Firmware Utility
BootUtil version 1.6.20.1
Copyright (C) 2003-2016 Intel Corporation
Type BootUtil -? for help
Port Network Address Location Series WOL Flash Firmware Version
1 90E2BAC2EE98 8:00.0 10GbE N/A PXE 2.1.40
2 90E2BAC2EE99 8:00.1 10GbE N/A PXE 2.1.40
C:\Intel21.1\APPS\BootUtil\Winx64>BOOTUTILW64E.EXE -FLASHENABLE -ALL //Set to FlashEnabled
Enabling boot ROM on port 1...Success
Reboot the system to enable the boot ROM on this port
Enabling boot ROM on port 2...Success
1 90E2BAC2EE98 8:00.0 10GbE N/A Reboot Required
2 90E2BAC2EE99 8:00.1 10GbE N/A Reboot Required
//I HAVE REBOOTED AFTER THIS STEP AND GOT SAME RESULTS
C:\Intel21.1\APPS\BootUtil\Winx64>BOOTUTILW64E.EXE -BOOTENABLE=iscsiprimary -ALL
Found discrete ROM in the flash for NIC 1
The -BOOTENABLE command can only be used on flashed combo images
Found discrete ROM in the flash for NIC 2
What is "The -BOOTENABLE command can only be used on flashed combo images"? I have tried to DISABLE as well and it does not take (same error message). I must be missing something but I am not sure what.
AAnth4
I am getting a little further. Found help from https://www.interworks.com/blog/tnguyen/2011/11/03/how-boot-iscsi-intel-x-520-mezzanine-card-dell-blades https://www.interworks.com/blog/tnguyen/2011/11/03/how-boot-iscsi-intel-x-520-mezzanine-card-dell-blades
Basically, I moved the BootIMG.FLB file from the C:\Intel21.1\APPS\BootUtil directory to the C:\Intel21.1\APPS\BootUtil\Winx64 directory. Then, I ran:
C:\Intel21.1\APPS\BootUtil\Winx64>BOOTUTILW64E.EXE -UP=combo -all
Programming flash on port 1 with flash firmware image
Create restore image of NIC 1 before proceeding? (Y)es or (N)o: N
Continue update without restore image? (Y)es or (N)o: Y
Flash update successful
Skipping port 2 (shared flash with previous port)
1 90E2BAC2EE98 8:00.0 10GbE N/A UEFI,PXE Enabled 2.3.72
2 90E2BAC2EE99 8:00.1 10GbE N/A UEFI,PXE Enabled 2.3.72
C:\Intel21.1\APPS\BootUtil\Winx64>BOOTUTILW64E.EXE -bootenable=iSCSIprimary -ALL
ERROR: iSCSI is not flashed on port 1
ERROR: iSCSI is not flashed on port 2
So, looks like iSCSI is not flashed. Sounds like I need to find the iSCSI FLB image. I don't see one in the zip file.
AAnth4
The commands are:
BOOTUTILW64E.EXE -UP=iSCSI -all //Update to ISCSI
BOOTUTILW64E.EXE -IV //This will then show below info.
Image versions in BootIMG.FLB
Combo Image Version Name 1.1450.0
Combo Rules v4.31.00
Clp-Loader Option ROM v3.0.67
40G Interface Module v1.0.38
iSCSI Option ROM v3.0.96
iSCSI Setup Option ROM v3.0.96
FCoE Option ROM v1.8.29
Intel(R) Boot Agent FE v4.2.08
Intel(R) Boot Agent GE v1.5.81
Intel(R) Boot Agent XE v2.3.72
Intel(R) Boot Agent I40E v1.0.47
Intel(R) Boot Agent CL v0.1.10
UEFI x64 PCI gigabit driver v3.5.22
UEFI x64 PCI-E gigabit driver v7.3.20
UEFI x64 10 gigabit driver v5.5.15
UEFI x64 40 gigabit driver v1.9.27
UEFI IA64 PCI gigabit driver v3.5.22
UEFI IA64 PCI-E gigabit driver v7.3.20
UEFI IA64 10 gigabit driver v5.5.15
UEFI IA64 40 gigabit driver v1.9.27
OCD Option ROM v0.9.04
UEFI x64 FCoE Driver v1.2.21
1 90E2BAC2EE98 8:00.0 10GbE N/A iSCSI 3.0.96
2 90E2BAC2EE99 8:00.1 10GbE N/A iSCSI 3.0.96
AAnth4
Any updates on this issue? It is still not resolved.
