Ethernet Products
5530 Discussions
Stablish uni-directional ethernet link
alireza11048
I am trying to establish a uni-directional Ethernet link where a singular fiber is used to transmit data to the receiver where both sides use ixgbe as driver. The Rx of the transmit side and the Tx of the receive side are not physically connected, like in a Data diode scenario.
To force links state to UP(as soon as I detach the TX line from one side, both side link status goes DOWN), i set FLU bit in AUTOC register and also i set the speed with LMS bits in the AUTOC register.
Links successfully become in up state, but I can not receive UDP packets that are sent from the TX side on the RX side.
Any advice to solve the problem in this mode is appreciated.
Yogaeasvaran
Greetings Alireza,
Thank you for contacting Intel Customer Support.
We will check you request from our resources and get back to you within 2 business days.
Thank You & Regards,
Yogaeasvaran
Yogaeasvaran
Greetings Alireza,
We need the SSU log for us to isolate the issue further.
Could you please provide us the SSU follow the link below:
Help Guide for the Intel® System Support Utility
Yogaeasvaran
alireza11048
Thanks for your reply,
output of the SSU file is attached.
P.S: i also want to mention that the Ethernet controller which i am experimenting  with it is intel 82599ES and the driver is ixgbe version 5.15.2.
thanks
Yogaeasvaran
Greetings Alireza,
To be informed that this type of configuration is not supported.
If you have any further questions or queries, please kindly let us know.
Yogaeasvaran
Yogaeasvaran
Greetings Alireza,
Regarding your case number 05930542, we are following up to find out if we can proceed to close this thread?
Please reply to this thread to confirm, so we can continue helping with a resolution. Looking forward to receiving your reply!
Yogaeasvaran
alireza11048
thank you for your follow-up,
I think in general this use case should be possible with the Intel ethernet products, as it was done in the "Development of Unidirectional Security Gateway Appliance using Intel 82580EB NIC Interface" paper.
but probably it needs special register-configuration of the ethernet controller.
Yogaeasvaran
Greetings Alireza,
Probably Yes as you mentioned.
We can suggest you post this question in embedded community to get the information you have requested.
Link: https://community.intel.com/t5/Embedded-Products/ct-p/embedded-products
Please do let me know if we can proceed for the closure.
Yogaeasvaran
Greetings Alizera,
Kindly note that as we have not received any response from our previous follow-ups, we will be closing this request.
If you have any more questions in the future, please don't hesitate to post a new question, as this thread will no longer be monitored.
Thank You & Regards
Yogaeasvaran
Intel® Customer Support
