Ethernet Products
5500 Discussions
Suport for vlan tagging at I219-LM interface
Flazeh
Hello there,
I have desktops with I219-LM interface installed, i need them to access lan traffic with vlan tagged. Does this interface have support for it?
I´ve been trying to configure it, with no success. I´ve followed the mainly in the article bellow.
https://community.intel.com/t5/Ethernet-Products/How-to-configure-Vlan-tagging-for-I210-IT-amp-I219-LM/m-p/1214721/thread-id/21888
I was able to run the poweshell commands, but it returns me an error.
PS C:\Windows\system32> Get-IntelNetAdapter
Location Name ConnectionName LinkStatus
0:31:6:0 Intel(R) Ethernet Connection (7) I219-LM 1,00 Gbps ...
PS C:\Windows\system32> Add-IntelNetVLAN
cmdlet Add-IntelNetVLAN na posição de comando 1 do pipeline
Forneça valores para os seguintes parâmetros:
ParentName[0]: Intel(R) Ethernet Connection (7) I219-LM
ParentName[1]:
VLANID[0]: 400
VLANID[1]:
Add-IntelNetVLAN : Falha em adicionar um ou mais dos IDs de VLAN especificados.
No linha:1 caractere:1
+ Add-IntelNetVLAN
+ CategoryInfo : InvalidOperation: (IANet_PhysicalE... = "CTA176302"):CimInstance) [Add-IntelNetVLAN], Ex
ception
+ FullyQualifiedErrorId : Erro de execução do cmdlet.,Intel.Network.VLAN.AddIntelNetVlan
Could you help me? In this case, it is a Windows 10.
Thanks in advance, Flávio
pujeeth
Hi Flazeh,
We have verified that Intel® Advanced Network Services is only supported on the Windows® 10 Anniversary Update (Windows 10 Version 1607, build 10.0.14393) branch. Unfortunately, it may not be supported on future versions of Windows®.
As you mentioned that the card came with the system, we would recommend reaching out to your OEM for further assistance.
Note: If you purchased an OEM-branded server or appliance, please contact your OEM for a software driver version compatible with your specific firmware version. Using software and firmware versions that have not been validated to work together may impact performance, feature availability, and system stability.
Additionally, we would request you to post a question on the Intel Community - Embedded Connectivity for further assistance.
Pujeeth
Simon-Intel
Hi Flazeh,
Thank you for contacting Intel support. We acknowledge receipt of your concern and want to assure you that assisting you is our top priority. To effectively troubleshoot the issue you're facing, we require some additional information from your end.
Could you kindly provide the following details?
1. System details:
2. Was the network adapter shipped along with the system or was it purchased separately:
Your prompt response with this information will greatly assist us in diagnosing and resolving the issue as quickly as possible.
Furthermore, you may refer to the below article for assistance:
https://www.intel.com/content/www/us/en/support/articles/000005677/ethernet-products.html
We look forward to hearing from you soon.
Simon
Flazeh
Hello Simon,
The interface was part of a Lenovo Desktop ThinkCentre M920 (https://www.lenovo.com/us/en/p/desktops/thinkcentre/m-series-tiny/thinkcentre-m920q/11tc1mtm92q).
It have a W11 installed.
Some more details follows:
Nome do dispositivo CTAXXXX
Nome completo do dispositivo CTAXXXX.local
Processador Intel(R) Core(TM) i5-9500T CPU @ 2.20GHz 2.21 GHz
RAM instalada 16,0 GB (utilizável: 15,7 GB)
ID do dispositivo 19C3A90A-51C2-43AF-A099-XXXXXXXXXX
ID do Produto 00331-10000-xxxxxx-xxxxx
Tipo de sistema Sistema operacional de 64 bits, processador baseado em x64
Caneta e toque Nenhuma entrada à caneta ou por toque disponível para este vídeo
Edição Windows 11 Pro
Versão 24H2
Instalado em ‎24/‎03/‎2025
Compilação do SO 26100.3194
Experiência Pacote de Experiência de Recursos do Windows 1000.26100.48.0
Best regards, Flávio
Amina_Sadiya
Hello
Thank you for your response, I would like to inform you that VLANs and teams is supported on Windows 10 and Windows Server 2016/2019, but not on Windows 11 or future Microsoft client operating systems.
 Kindly refer to the below link for Creating Intel® Advanced Network Services Teams and VLANs on Windows® 10
https://www.intel.com/content/www/us/en/support/articles/000022282/ethernet-products.html#:~:text=Operating%20System&text=%C2%AE%2010%20family-,Creating%20Intel%C2%AE%20Advanced%20Network%20Services%20teams%20and%20VLANs%20on,the%20feature%20to%20be%20enabled.&text=Any%20Intel%C2%AE%20Advanced%20Network,get%20the%20original%20names%20back.&text=Int....
Amina
Flazeh
Hello Amina,
Thanks por the response, but I have my doubts about your affirmation: I have an Acer notebook with a Realtek network interface and  Windows 11 installed. It HAS the option to set the vlan ID at the Device Manager - Interface - Properties - Advanced  - VLAN ID (like this article: https://woshub.com/configure-multiple-vlan-on-windows/).
I suspect that is something about the Intel interface chipset (I219-LM) or the driver. Maybe some resource with a different approach to enable.
Could it be something alse, or how can I do it, please?
pujeeth
Hi Flazeh,
Pujeeth
