Ethernet Products
4616 Discussions
TSE Ethernet RGMII for NiosII running Linux
I have been trying to get a SoC that would run Linux for the NiosII. Then I want it to support Ethernet. I have been using TSE so far, but no success.
Does anyone has some ideas about how I could have a starting point? I would like to have a functional system that would run Linux on NiosII and support TSE with RGMII. I have tried so many permutations on the design, but I have not succeeded so far.
this is part of my code:
// This code is generated by Terasic System Builder
module de2_115_dtlinux_ethernet(
//////////// CLOCK //////////
CLOCK_50,
CLOCK2_50,
CLOCK3_50,
//////////// Ethernet 0 //////////
ENET0_GTX_CLK,
ENET0_INT_N,
ENET0_LINK100,
ENET0_MDC,
ENET0_MDIO,
ENET0_RST_N,
ENET0_RX_CLK,
ENET0_RX_COL,
ENET0_RX_CRS,
ENET0_RX_DATA,
ENET0_RX_DV,
ENET0_RX_ER,
ENET0_TX_CLK,
ENET0_TX_DATA,
ENET0_TX_EN,
ENET0_TX_ER,
ENETCLK_25,
//////////// SDRAM //////////
DRAM_ADDR,
DRAM_BA,
DRAM_CAS_N,
DRAM_CKE,
DRAM_CLK,
DRAM_CS_N,
DRAM_DQ,
DRAM_DQM,
DRAM_RAS_N,
DRAM_WE_N
// PARAMETER declarations
// PORT declarations
input CLOCK_50;
input CLOCK2_50;
input CLOCK3_50;
output ENET0_GTX_CLK;
input ENET0_INT_N;
input ENET0_LINK100;
output ENET0_MDC;
inout ENET0_MDIO;
output ENET0_RST_N;
input ENET0_RX_CLK;
input ENET0_RX_COL;
input ENET0_RX_CRS;
input [3:0] ENET0_RX_DATA;
input ENET0_RX_DV;
input ENET0_RX_ER;
input ENET0_TX_CLK;
output [3:0] ENET0_TX_DATA;
output ENET0_TX_EN;
output ENET0_TX_ER;
input ENETCLK_25;
output [12:0] DRAM_ADDR;
output [1:0] DRAM_BA;
output DRAM_CAS_N;
output DRAM_CKE;
output DRAM_CLK;
output DRAM_CS_N;
inout [31:0] DRAM_DQ;
output [3:0] DRAM_DQM;
output DRAM_RAS_N;
output DRAM_WE_N;
// REG/WIRE declarations
wire eth_mode, ena_10;
wire core_reset_n;
wire sys_clk, clk_125, clk_25, clk_2p5, tx_clk;
wire mdc, mdio_in, mdio_oen, mdio_out;
// Structural coding
assign ENET0_RESET_N = core_reset_n;
assign mdio_in = ENET0_MDIO;
assign ENET0_MDC = mdc;
assign ENET0_MDIO = mdio_oen ? 1'bz : mdio_out;
assign tx_clk = eth_mode ? clk_125 : // GbE Mode = 125MHz clock
ena_10 ? clk_2p5 : // 10Mb Mode = 2.5MHz clock
clk_25; // 100Mb Mode = 25 MHz clock
tse_pll tse_pll_inst
//.areset(areset_sig) , // input areset_sig
.inclk0(CLOCK_50) , // input inclk0_sig
.c0(sys_clk) , // output c0_sig
.c1(clk_125) , // output c1_sig
.c2(clk_25) , // output c2_sig
.c3(clk_2p5) , // output c3_sig
.locked(core_reset_n) // output locked_sig
tse_ddio tse_ddio_inst
.datain_h(1'b1) , // input [0:0] datain_h_sig
.datain_l(1'b0) , // input [0:0] datain_l_sig
.outclock(tx_clk) , // input outclock_sig
.dataout(ENET0_GTX_CLK) // output [0:0] dataout_sig
SoC4DTLinux u0 (
.altpll_0_c1_sdram_clk_clk (DRAM_CLK), // altpll_0_c1_sdram_clk.clk
.clk_clk (CLOCK_50), // clk.clk
.reset_reset_n (1'b1), // reset.reset_n
.sdram_mem_controller_wire_addr (DRAM_ADDR), // sdram_mem_controller_wire.addr
.sdram_mem_controller_wire_ba (DRAM_BA), // .ba
.sdram_mem_controller_wire_cas_n (DRAM_CAS_N), // .cas_n
.sdram_mem_controller_wire_cke (DRAM_CKE), // .cke
.sdram_mem_controller_wire_cs_n (DRAM_CS_N), // .cs_n
.sdram_mem_controller_wire_dq (DRAM_DQ), // .dq
.sdram_mem_controller_wire_dqm (DRAM_DQM), // .dqm
.sdram_mem_controller_wire_ras_n (DRAM_RA_N), // .ras_n
.sdram_mem_controller_wire_we_n (DRAM_WE_N), // .we_n
.tse_pcs_mac_tx_clock_connection_clk (tx_clk), // tse_pcs_mac_tx_clock_connection.clk
.tse_pcs_mac_rx_clock_connection_clk (ENET0_RX_CLK), // tse_pcs_mac_rx_clock_connection.clk
.tse_mac_status_connection_set_10 (1'b0), // tse_mac_status_connection.set_10
.tse_mac_status_connection_set_1000 (1'b0), // .set_1000
.tse_mac_status_connection_eth_mode (eth_mode), // .eth_mode
.tse_mac_status_connection_ena_10 (ena_10), // .ena_10
.tse_mac_rgmii_connection_rgmii_in (ENET0_RX_DATA), // tse_mac_rgmii_connection.rgmii_in
.tse_mac_rgmii_connection_rgmii_out (ENET0_TX_DATA), // .rgmii_out
.tse_mac_rgmii_connection_rx_control (ENET0_RX_DV), // .rx_control
.tse_mac_rgmii_connection_tx_control (ENET0_TX_EN), // .tx_control
.tse_mac_mdio_connection_mdc (mdc), // tse_mac_mdio_connection.mdc
.tse_mac_mdio_connection_mdio_in (mdio_in), // .mdio_in
.tse_mac_mdio_connection_mdio_out (mdio_out), // .mdio_out
.tse_mac_mdio_connection_mdio_oen (mdio_oen) // .mdio_oen
endmodule
