I know that the Ta range is 0°C to 70°C, but could you share more detailed temperature information?
For example, what is the Tj MAX (Maximum Junction Temperature) or Tc MAX (Maximum Case Temperature)?
Hi Jiayu5577,
Greetings!
As per checking we have found that you already have an existing case with us. Please continue to use that case for further communication.
Besides that, you may find the needed information in the datasheet by using the following link: https://cdrdv2.intel.com/v1/dl/getContent/596659?explicitVersion=true
But to access this document you will need a CNDA. Please go through the following link for the steps to apply for one: https://www.intel.com/content/www/us/en/support/articles/000058073/programs/resource-and-documentation-center.html
Thank you & Best Regards,
Ragulan_Intel
Hi Jiayu5577,
Greetings!
Ragulan_Intel
Hello Team,
Greetings of the day!
Thank you for confirmation. We will go ahead and close this case.
kindly reach out to us for your query we are happy to help you.
Amina
