Hello, I am now in test sriov mode of the virtual machine network performance, i using two 82599 nic CARDS created eight vf respectively, and then took out two vf card to a virtual machine. During the test by ethtool -S I found that only a queue receiving packets,
through the datasheet i found that if need use multiple queue in vf need configue DCB and tc.
Now i had configuration DCB and TC,but receive packages can only use single queue problem still unsolved
How should I Do to use multiple queues to receive packets in vf?
[root@host ~]# dcbtool gc eth5 dcb
Command: Get Config
Feature: DCB State
Port: eth5
Status: Successful
DCB State: on
[root@host ~]# dcbtool gc eth5 pg
Command: Get Config
Feature: Priority Groups
Port: eth5
Status: Successful
Enable: true
Advertise: true
Willing: true
up2tc: 0 1 2 3 4 5 6 7
pgpct: 13% 13% 13% 13% 12% 12% 12% 12%
pgid: 0 1 2 3 4 5 6 7
uppct: 100% 100% 100% 100% 100% 100% 100% 100%
pg strict: 0 0 0 0 0 0 0 0
num TC's: 8
[root@host ~]# tc qdisc add dev eth5 root mqprio num_tc 8
[root@host ~]# tc qdisc show dev eth5
qdisc mqprio 800a: root tc 8 map 0 1 2 3 4 5 6 7 0 1 1 1 3 3 3 3
queues:(0:0) (1:1) (2:2) (3:3) (4:4) (5:5) (6:6) (7:7)
qdisc pfifo_fast 0: parent 800a:8 bands 3 priomap 1 2 2 2 1 2 0 0 1 1 1 1 1 1 1 1
qdisc pfifo_fast 0: parent 800a:7 bands 3 priomap 1 2 2 2 1 2 0 0 1 1 1 1 1 1 1 1
qdisc pfifo_fast 0: parent 800a:6 bands 3 priomap 1 2 2 2 1 2 0 0 1 1 1 1 1 1 1 1
qdisc pfifo_fast 0: parent 800a:5 bands 3 priomap 1 2 2 2 1 2 0 0 1 1 1 1 1 1 1 1
qdisc pfifo_fast 0: parent 800a:4 bands 3 priomap 1 2 2 2 1 2 0 0 1 1 1 1 1 1 1 1
qdisc pfifo_fast 0: parent 800a:3 bands 3 priomap 1 2 2 2 1 2 0 0 1 1 1 1 1 1 1 1
qdisc pfifo_fast 0: parent 800a:2 bands 3 priomap 1 2 2 2 1 2 0 0 1 1 1 1 1 1 1 1
qdisc pfifo_fast 0: parent 800a:1 bands 3 priomap 1 2 2 2 1 2 0 0 1 1 1 1 1 1 1 1
And there is one another question, in the 82599 datasheet, it said that if turn off DCB and set RSS on, when create 16 vf, one pool would be get 4 RSS. IN my test, i found there are 4 RSS when use ethtool -l $NIC. But in the VM, i use ethtool -S $nic, only get 2 rx queue. where is the problem.
