Ethernet Products
5435 Discussions
The x550 network card reports an error when it is powered down
178peng
Hello,I encountered a problem when using the x550 network card. This error occurs when the device is powered down:
driver version: 5.1.0-k-rh8.1.0
firmware version: 0x80001751,1.3064.0
Mike_Intel
Hello 178peng,
For us to further check the issue, please provide the following details.
  1. Are you using a PCIe card X550 or is it embedded on the board?
  2. Are you getting this error message inside the OS?
  3. What is your OS?
  4. Is it working fine before?
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
Intel® Customer Support
Mike_Intel
Hello 178peng,
I hope you're having a wonderful day. I am just sending a soft follow up on the information that we requested for us to further assist you. We will wait for your reply.
Michael L.
Mike_Intel
Hello 178peng,
I hope this message finds you well. I am just sending another follow up on the information that I requested. Since we have not heard back from you, I need to close this inquiry.
Thank you and stay safe.
Michael L.
