Ethernet Products
5707 Discussions
Two questions about X710-AT2
jackylee0908
Hi sir,
I have a server system with the onboard X710-AT2 Ethernet controller, I met two issues here:
1. Sometimes the FW flash failed by nvmupdatew64e tool under Windows Server 2022 with latest X710-AT2 driver package v28.2.1 installed, see below screenshot, the failure rate is about 5%.
Say that, when I try to update the FW, but it failed, so then I create a simple batch to flash it for 100 times, and 5 of 100 got the issue.
The tool I used is downloaded from Intel, the version is 1.39.56.8, and the X710 FW version I'd want to flash is v9.30, the image also is downloaded from same Intel X710 webpage.
Please advise if it relates to tool or driver or even a HW issue.
2. When I try to run the X710 performance test thru NTTTCP tool(the same OS and driver and FW mentioned in above), I got error counters like below screenshot.
The tool I used is with latest version v5.39, the connection I used is connect two X710-AT2 ports cross two the same servers.
As I know the NTTTCP tool is developed by Microsoft, but I don't know what mean for the error counters since I cannot get more information about this tool, also I aware the Retransmits also got counters.
Is there any way or tool from Intel that can help me to clarify the issue?
Jacky
IntelSupport
Community Manager
Hello jackylee0908,
Kindly provide below details to know more on your system.
NIC Image:
Windows:
CPU:
BIOS:
Server name:
You can update your Intel® Network Adapter Driver for Windows Server 2022 if you don’t have the latest version yet.
You can check this Quick Usage Guide for Intel® Ethernet NVM Update Tool for Microsoft Windows as well.
Kindly check this out Tuning Throughput Performance for Intel® Ethernet Adapters
Please let us know the outcome after you have checked it and will be happy to assist if any other troubleshooting required for this issue.
Thank you.
Hayat
jackylee0908
Hi Hayat,
FYI.
NIC Image: Release_28.2.1.zip
Windows: Windows Server 2022
CPU: Intel Xeon Silver 4310T
BIOS: v1.20
Server name: ASRock SPC621D8U-2T
Jacky
IntelSupport
Community Manager
Hello jackylee0908,
Thank you for your response.
Kindly provide us the NIC picture of Intel® X710-AT2
Thank you.
Hayat
jackylee0908
Hi Hayat,
X710-AT2 is an onboard controller on ASRock server board, not a NIC card.
Jacky
IntelSupport
Community Manager
Hello jackylee0908
Since it is an onboard controller, we would suggest you to contact ASRock support.
You might need to do a Clean Driver Installation Guide for Intel® Ethernet Connections since you have installed the driver from direct Intel.
As the Intel ethernet controller is directly from ASRock Server, they might have their own driver update for this.
Please let us know after you have contact ASRock support and will be happy to assist if any other troubleshooting required for this issue.
Else if none, please confirm the closure of the thread.
Thank you.
Hayat
jackylee0908
Hi Hayat,
Got it, I will try to contact ASRock for those issues and let you know if I have any updates.
Jacky
IntelSupport
Community Manager
Hello jackylee0908,
Sure, please let us know once you have receive an update.
If you have any other queries, we will be glad to assist.
Thank you.
Hayat
Intel Customer Support
IntelSupport
Community Manager
Hello jackylee0908,
Have you received any update from ASRock?
Please let us know if you have any questions.
Else if none, we will proceed with case closure.
Kindly update us on this.
Thank you.
Hayat
IntelSupport
Community Manager
Hi jackylee0908,
Since we receive no more response from your end, we will proceed with thread closure.
If you have any additional queries, kindly submit a new case as this thread will no longer be monitored.
Thank you
Hayat
Intel® Customer Support
