Hello Team,
This is Parag from Flex-Component engg. I need your support on the below listed parts from Intel.
Please help me to provide the data as soon as possible.
ITEM NUMBER | DESCRIPTION | MPN | STORAGE TEMPRATURE | REFLOW TEMPARETURE | DATASHEET LINK/PDF |
FFV1H-ICS-1043-00 | IC,LAN,X557-AT4,FCBGA,576P | EZX557AT4 SLKW3, 941995 | |||
FFV1H-CPU-0222-01 | NIL, CPU, ATOM PROCESSOR, P532 | NN8069204099502 SRL3R, 99AM3N |
Waiting for your response.
Kindly share the information via email. It will help for us.
Hello Team,
A Gentle Reminder.
Hello PARAGSEHNAI,
Below are information that you need for Intel® Ethernet Connection X557-AT4.
But please be informed that we do not support ATOM. Thus we do not have the datasheet handy with us now.
Rest assure, we will transfer you to the correct team for the Intel Atom® Processor P5322 datasheet.
ITEM NUMBER |
DESCRIPTION |
MPN |
FFV1H-ICS-1043-00 |
FFV1H-CPU-0222-01 |
Nurhayati
Hello Nurhayti,
Thanks a lot for your response.
1. For EZX557AT4 SLKW3, 941995 this part number I found storage temperature but can't find reflow temperature. Could you please help me to provide it as soon as possible? It is very urgent request from our side.
2. For NN8069204099502 SRL3R, 99AM3N this part number, I am not able to open the datasheet link provided by you. So that didn't get required data by this link. Could you please help me to confirm once? You can fill the table below with the PDF/datasheet.
If possible, then please provide us the correct contact person/Email for this request so that we can directly contact via Email.
Hello PARAGSEHNAI,
Thank you for your reply.
Please also try the new link I provided for Intel Atom® Processor P5322.
We will get back to you as soon as we received the information on the Intel Atom® Processor P5322 datasheet.
ITEM NUMBER |
DESCRIPTION |
MPN |
FFV1H-ICS-1043-00 |
Operating Temperature Range 0°C to 55°C Operating Temperature (Maximum) 55 °C Operating Temperature (Minimum) 0 °C |
FFV1H-CPU-0222-01 |
Nurhayati
Hello PARAGSEHNAI,
I have an update for you. Please go thru below link to find the datasheet for Intel Atom® Processor P5322:
https://www.intel.com/content/www/us/en/support/articles/000006900/processors.html
I would also like to confirm with you if you could contact your field Application Engineer (FAE) or AE to get the information since this processor is a tray units.
Please let us know the outcome after you have checked it and will be happy to assist if any other troubleshooting required for this issue.
Nurhayati
Hi PARAGSEHNAI,
Regarding your thread, we are following up to find out if you were able to complete the actions, we previously recommended.
Please reply to this email to confirm, so we can continue helping with a resolution. Looking forward to receiving your reply!
Thank You.
Nurhayati
Intel® Customer Support
Hello PARAGSHENAI,
Good day,
This message is to inform you about the thread closure. Since a new case has been open, we will now communicate thru the new case by email.
Once the thread is closed, it will no longer be monitored by Intel.
Nurhayati
Hello Nurhayati,
Good day!!
Thanks for your response.
Could you please help me to provide the details which you have with you via email?? As I am facing difficulties while communicating from here. And I didn't get the proper response from your end as well. Please help me to support by email. I have received one email from Intel Support regarding the case creation, but i am not able to find out from where we can be reaching to the case.
Requesting you to share your email ID. It will help us a lot.
Parag.
Hello Nurhayati,
Good day!!
Parag.
Hello Nurhayati,
Good day!!
Parag.
