Ethernet Products
5719 Discussions
Unable to compile NAPI enabled ixgbe driver on Fedora 18
NPrak1
I'm having an issue making the latest ixgbe driver (3.15.1) with NAPI enabled. No matter how I try to compile it, it won't show -napi at the end of the version. Is there a parameter I could check whether my kernal has NAPI enabled?gbe
[root@linux ~]# modinfo ixgbe
filename: /lib/modules/3.9.4-200.fc18.x86_64/kernel/drivers/net/ethernet/intel/ixgbe/ixgbe.ko
version: 3.15.1
license: GPL
description: Intel(R) 10 Gigabit PCI Express Network Driver
author: Intel Corporation, <</span>mailto:linux.nics@intel.com linux.nics@intel.com>
srcversion: 9355E6A8DE2F272233819DA
alias: pci:v00008086d0000155Dsv*sd*bc*sc*i*
alias: pci:v00008086d0000155Csv*sd*bc*sc*i*
alias: pci:v00008086d00001557sv*sd*bc*sc*i*
alias: pci:v00008086d0000154Fsv*sd*bc*sc*i*
alias: pci:v00008086d0000154Dsv*sd*bc*sc*i*
alias: pci:v00008086d00001528sv*sd*bc*sc*i*
alias: pci:v00008086d000010F8sv*sd*bc*sc*i*
alias: pci:v00008086d0000151Csv*sd*bc*sc*i*
alias: pci:v00008086d00001529sv*sd*bc*sc*i*
alias: pci:v00008086d0000152Asv*sd*bc*sc*i*
alias: pci:v00008086d000010F9sv*sd*bc*sc*i*
alias: pci:v00008086d00001514sv*sd*bc*sc*i*
alias: pci:v00008086d00001507sv*sd*bc*sc*i*
alias: pci:v00008086d000010FBsv*sd*bc*sc*i*
alias: pci:v00008086d00001517sv*sd*bc*sc*i*
alias: pci:v00008086d000010FCsv*sd*bc*sc*i*
alias: pci:v00008086d000010F7sv*sd*bc*sc*i*
alias: pci:v00008086d00001508sv*sd*bc*sc*i*
alias: pci:v00008086d000010DBsv*sd*bc*sc*i*
alias: pci:v00008086d000010F4sv*sd*bc*sc*i*
alias: pci:v00008086d000010E1sv*sd*bc*sc*i*
alias: pci:v00008086d000010F1sv*sd*bc*sc*i*
alias: pci:v00008086d000010ECsv*sd*bc*sc*i*
alias: pci:v00008086d000010DDsv*sd*bc*sc*i*
alias: pci:v00008086d0000150Bsv*sd*bc*sc*i*
alias: pci:v00008086d000010C8sv*sd*bc*sc*i*
alias: pci:v00008086d000010C7sv*sd*bc*sc*i*
alias: pci:v00008086d000010C6sv*sd*bc*sc*i*
alias: pci:v00008086d000010B6sv*sd*bc*sc*i*
depends: dca
vermagic: 3.9.4-200.fc18.x86_64 SMP mod_unload
parm: InterruptType:Change Interrupt Mode (0=Legacy, 1=MSI, 2=MSI-X), default IntMode (deprecated) (array of int)
parm: IntMode:Change Interrupt Mode (0=Legacy, 1=MSI, 2=MSI-X), default 2 (array of int)
parm: MQ:Disable or enable Multiple Queues, default 1 (array of int)
parm: DCA:Disable or enable Direct Cache Access, 0=disabled, 1=descriptor only, 2=descriptor and data (array of int)
parm: RSS:Number of Receive-Side Scaling Descriptor Queues, default 0=number of cpus (array of int)
parm: VMDQ:Number of Virtual Machine Device Queues: 0/1 = disable, 2-16 enable (default=8) (array of int)
parm: max_vfs:Number of Virtual Functions: 0 = disable (default), 1-63 = enable this many VFs (array of int)
parm: L2LBen:L2 Loopback Enable: 0 = disable, 1 = enable (default) (array of int)
parm: InterruptThrottleRate:Maximum interrupts per second, per vector, (0,1,956-488281), default 1 (array of int)
parm: LLIPort:Low Latency Interrupt TCP Port (0-65535) (array of int)
parm: LLIPush:Low Latency Interrupt on TCP Push flag (0,1) (array of int)
parm: LLISize:Low Latency Interrupt on Packet Size (0-1500) (array of int)
parm: LLIEType:Low Latency Interrupt Ethernet Protocol Type (array of int)
parm: LLIVLANP:Low Latency Interrupt on VLAN priority threshold (array of int)
parm: FdirPballoc:Flow Director packet buffer allocation level:
1 = 8k hash filters or 2k perfect filters
2 = 16k hash filters or 4k perfect filters
3 = 32k hash filters or 8k perfect filters (array of int)
parm: AtrSampleRate:Software ATR Tx packet sample rate (array of int)
parm: FCoE:Disable or enable FCoE Offload, default 1 (array of int)
parm: LRO:Large Receive Offload (0,1), default 1 = on (array of int)
parm: allow_unsupported_sfp:Allow unsupported and untested SFP+ modules on 82599 based adapters, default 0 = Disable (array of int)
dmesg:
[ 1022.867423] Intel(R) 10 Gigabit PCI Express Network Driver - version 3.15.1
[ 1022.867424] Copyright (c) 1999-2013 Intel Corporation.
[ 1022.867865] ixgbe: 0000:1f:00.0: ixgbe_check_options: FCoE Offload feature enabled
[ 1023.030542] ixgbe 0000:1f:00.0: irq 68 for MSI/MSI-X
[ 1023.030551] ixgbe 0000:1f:00.0: irq 69 for MSI/MSI-X
[ 1023.030558] ixgbe 0000:1f:00.0: irq 70 for MSI/MSI-X
[ 1023.030566] ixgbe 0000:1f:00.0: irq 71 for MSI/MSI-X
[ 1023.030574] ixgbe 0000:1f:00.0: irq 72 for MSI/MSI-X
[ 1023.030582] ixgbe 0000:1f:00.0: irq 73 for MSI/MSI-X
[ 1023.030589] ixgbe 0000:1f:00.0: irq 74 for MSI/MSI-X
[ 1023.030597] ixgbe 0000:1f:00.0: irq 75 for MSI/MSI-X
[ 1023.030604] ixgbe 0000:1f:00.0: irq 76 for MSI/MSI-X
[ 1023.030612] ixgbe 0000:1f:00.0: irq 77 for MSI/MSI-X
[ 1023.030619] ixgbe 0000:1f:00.0: irq 78 for MSI/MSI-X
[ 1023.030627] ixgbe 0000:1f:00.0: irq 79 for MSI/MSI-X
[ 1023.030635] ixgbe 0000:1f:00.0: irq 80 for MSI/MSI-X
[ 1023.030643] ixgbe 0000:1f:00.0: irq 81 for MSI/MSI-X
[ 1023.030651] ixgbe 0000:1f:00.0: irq 82 for MSI/MSI-X
[ 1023.030658] ixgbe 0000:1f:00.0: irq 83 for MSI/MSI-X
[ 1023.030666] ixgbe 0000:1f:00.0: irq 84 for MSI/MSI-X
[ 1023.032512] ixgbe 0000:1f:00.0: (PCI Express:5.0GT/s:Width x8) 90:e2:ba:18:c4:94
[ 1023.032845] ixgbe 0000:1f:00.0 eth4: MAC: 2, PHY: 12, SFP+: 5, PBA No: G43015-001
[ 1023.032851] ixgbe 0000:1f:00.0 eth4: Enabled Features: RxQ: 16 TxQ: 16 FdirHash RSC
[ 1023.032883] ixgbe 0000:1f:00.0 eth4: Intel(R) 10 Gigabit Network Connection
[ 1023.033225] ixgbe: 0000:1f:00.1: ixgbe_check_options: FCoE Offload feature enabled
[ 1023.058493] systemd-udevd[1839]: renamed network interface eth4 to p4p1
[ 1023.236420] IPv6: ADDRCONF(NETDEV_UP): p4p1: link is not ready
[ 1023.301750] ixgbe 0000:1f:00.0 p4p1: detected SFP+: 5
[ 1023.436512] ixgbe 0000:1f:00.0 p4p1: NIC Link is Up 10 Gbps, Flow Control: RX/TX
[ 1023.436635] IPv6: ADDRCONF(NETDEV_CHANGE): p4p1: link becomes ready
[ 1024.146214] ixgbe 0000:1f:00.1: irq 85 for MSI/MSI-X
[ 1024.146226] ixgbe 0000:1f:00.1: irq 86 for MSI/MSI-X
[ 1024.146234] ixgbe 0000:1f:00.1: irq 87 for MSI/MSI-X
[ 1024.146242] ixgbe 0000:1f:00.1: irq 88 for MSI/MSI-X
[ 1024.146249] ixgbe 0000:1f:00.1: irq 89 for MSI/MSI-X
[ 1024.146257] ixgbe 0000:1f:00.1: irq 90 for MSI/MSI-X
[ 1024.146265] ixgbe 0000:1f:00.1: irq 91 for MSI/MSI-X
[ 1024.146272] ixgbe 0000:1f:00.1: irq 92 for MSI/MSI-X
[ 1024.146280] ixgbe 0000:1f:00.1: irq 93 for MSI/MSI-X
[ 1024.146287] ixgbe 0000:1f:00.1: irq 94 for MSI/MSI-X
[ 1024.146295] ixgbe 0000:1f:00.1: irq 95 for MSI/MSI-X
[ 1024.146304] ixgbe 0000:1f:00.1: irq 96 for MSI/MSI-X
[ 1024.146311] ixgbe 0000:1f:00.1: irq 97 for MSI/MSI-X
[ 1024.146318] ixgbe 0000:1f:00.1: irq 98 for MSI/MSI-X
[ 1024.146326] ixgbe 0000:1f:00.1: irq ...
