Ethernet Products
4620 Discussions
Unable to compile i40e driver in Ubuntu 18.04.5 for an Intel X710 Dual 10 GB NIC
Pakito
Hi There,
I am trying to compile the i40e driver for an Intel X710 Dual 10 GbE Card.
See below details:
OS: Ubuntu 18.04.5 LTS
Kernel Version:4.15.0-159-generic
Intel Driver versions I have tried to install: i40e-2.11.25 ,i40e-2.16.11
I have SRIOV, IOMMU and NUMA topology on the BIOS /grub.
The server Manufacturer is Dell R440
See below PCI info:
driver: i40e
version: 2.1.14-k
firmware-version: 8.15 0x800096c1 20.0.17
expansion-rom-version:
bus-info: 0000:3b:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
iproute2 version:  5.8.0
We also upgraded the Intel X710 NVM version from v7.0 to v8.15 with the same result.
See below error when compiling the i40 e driver:
root@sub-sandvine01:/root# cd i40e-2.11.25/src
root@sub-sandvine01:/root/i40e-2.11.25/src# make install
make[1]: Entering directory '/usr/src/linux-headers-4.15.0-159-generic'
  CC [M]  /root/i40e-2.11.25/src/i40e_main.o
In file included from /root/i40e-2.11.25/src/i40e.h:33:0,
                 from /root/i40e-2.11.25/src/i40e_main.c:8:
/root/i40e-2.11.25/src/kcompat.h:6796:28: error: redefinition of ‘skb_frag_off
 static inline unsigned int skb_frag_off(const skb_frag_t *frag)
In file included from ./include/linux/tcp.h:21:0,
                 from ./include/net/tcp.h:24,
                 from /root/i40e-2.11.25/src/i40e.h:7,
./include/linux/skbuff.h:2763:28: note: previous definition of ‘skb_frag_off’ was here
scripts/Makefile.build:333: recipe for target '/root/i40e-2.11.25/src/i40e_main.o' failed
make[2]: *** [/root/i40e-2.11.25/src/i40e_main.o] Error 1
Makefile:1590: recipe for target '_module_/root/i40e-2.11.25/src' failed
make[1]: *** [_module_/root/i40e-2.11.25/src] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-4.15.0-159-generic'
Makefile:69: recipe for target 'default' failed
make: *** [default] Error 2
Are you able to assist ? Thanks.
Mike_Intel
Hello Pakito,
For us to further check the issue, please provide the following details.
Kindly provide us with a brief detailed description of what you wish you to accomplish. From the initial entry it seems like this would be a driver compilation for the Intel® Ethernet Converged Network Adapter XL710, however more details are required. Please provide the markings for your network adapter or provide a photo of your network card on both sides for us to validate if it belongs to a Retail version, or an OEM (Original Equipment Manufacturer).
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
Pakito
Hi Michael ,
Correct we are trying to compile the driver for the Intel X710 dual port 10 GbE.
I am unable to get a photo of the Intel card, how can I get the markings on the card?
Francisco
Mike_Intel
Hello Pakito,
Thank you for the quick reply. By the way, are you using a program to compile the driver? If yes, please tell us.
If you cannot get the markings, let us try getting the markings via ssu logs. Kindly download the utility below:
https://www.intel.com/content/www/us/en/download/18895/intel-system-support-utility-for-the-linux-operating-system.html?wapkw=ssu
Michael L.
Mike_Intel
Hello Pakito,
I hope you enjoyed your weekend. I am just making a follow up on the ssu for us to check the card.
Michael L.
RistoVF
Hi all,
I have a similar situation when I upgraded my kernel on Debian from 4.19.0-17 (4.19.194) to 4.19.0-18 (4.19.208). In between those versions (4.19.201) skb_frag_off function was added in the kernel /usr/src/linux-headers-4.19.0-18-common/include/linux/skbuff.h file (https://yhbt.net/lore/all/20210802134334.892201802@linuxfoundation.org/t/)
The i40e driver has a check:
#if (LINUX_VERSION_CODE < KERNEL_VERSION(5,4,0))
in src/kcompat_std_defs.h that causes the conflicting function to be included.
Checked in: https://www.intel.com/content/www/us/en/download/18026/intel-network-adapter-driver-for-pcie-40-gigabit-ethernet-network-connections-under-linux.html
There is no need for a network card to be present to make this error appear—you only need to run "make" in the driver src folder when the updated kernel is loaded.
Basically you should update the driver package to check the kernel version in a way that it notices the kernels that have the functions built-in and do not need NEED_SKB_FRAG_OFF_ACCESSORS anymore. I was able to compile the driver after I undefined the   NEED_SKB_FRAG_OFF_ACCESSORS.
BR,
Risto
Mike_Intel
Hello Pakito,
I am just sending another follow up on the information that I requested.
If you need further assistance, please post a new question.
Hello RistoVF,
For us to check your inquiry and gather the needed details, please post a new question to create a separate thread.
Thank you and stay safe.
Michael L.
