Hi!
I own a plenty of PRO/1000 PT Single port adapters in Retail versions, not OEM
(D50855-003, EXPI9300PTLPBLK, 82572El based) and i'd like to flash iSCSI rom.
I tried bootutil versions 1.6.57.0 and 1.7.26.3 with no success:
# ./bootutil64e -nic 1 -up iscsi -file ../BootIMG.FLB
Intel(R) Ethernet Flash Firmware Utility
BootUtil version 1.6.57.0
Copyright (C) 2003-2017 Intel Corporation
iscsi is not a valid image type for port 1
Port Network Address Location Series WOL Flash Firmware Version
1 001B211A2920 2:00.0 Gigabit NO PXE 1.5.89
root@pentium:~/Preboot_22/APPS/BootUtil/Linux_x64#
I suppose i need older ROM or older bootutil or both. Please help me to find it or to find my mistake if there is any.
I understand that this is EOL product, but i hope that won't be a problem.
Hello Kreksoverzum,
Please provide the following information that would help in checking your request.
1.) Kindly confirm if BootUtil was downloaded from link below? If no, please share the link where the utility was downloaded from.
Intel® Ethernet Connections Boot Utility, Preboot Images, and EFI Drivers
2.) How many adapters are affected by the issue?
3.) What is the current driver version of your PRO/1000 PT?
4.) Operating System used
5.) When you mentioned that you have plenty of PRO/1000 PT Single port adapters in Retail versions and not OEM, do they all have the same PBA number as below?
D50855-003
We hope to hear from you soon.
Should there be no response from you, I’ll make sure to reach out after 3 business days.
Crisselle C
Intel® Customer Support
Thank you for your reply.
1.) Yes. I tried two versions. This one and https://downloadcenter.intel.com/download/27539/Ethernet-Intel-Ethernet-Connections-Boot-Utility-Pre...
2.) I tried with two. There are five more, pretty identical
3.) modinfo says it is e1000e version 3.2.6-k
4.) Ubuntu 18.04 x86_64 with 4.15.0-135 kernel
5.) Yes
I have successfully updated pxe rom on this adapter with "-UP PXE". And even more, yesterday i have successfully flashed iscsi rom into EXPI9301CT (Desktop Gigabit CT adapter) installed in the same box. So, I believe, it is not OS or driver failure. However, it can be
And there is one more odd thing: before upgrading pxe rom with "-UP PXE", i was unable to save old image with -SAVEIMAGE and rom version was marked as Unknown. After upgrading -SI flag works. Note, that on the screenshot similar case is depicted but not as exactly described.
Origin of these cards is nebulous and doubtful. That's why a attach photos of the card
Hello Kreksoverzum,
You're welcome, appreciate your effort in sending the requested information.
Please allow us to further check on this. We will get back to you as soon as possible but no later than 2-3 business days.
Hoping for your kind patience.
Crisselle C
Hello Kreksoverzum,
We hope you had a great weekend!
We've sent an email as our engineering team is requesting for Intel® System Support Utility(SSU) logs from your system to further check this request. Please be reminded to attach the SSU logs when replying to our email and not on this thread to avoid exposing sensitive information.
We will make sure to reach out after 3 business days in case we don't hear from you.
Crisselle C
Hello Kreksoverzum,
Good day!
This is just a follow up for the additional information that we are requesting for. Kindly reply to our email and attach the the SSU logs for us to continue with the investigation. In case you need more time on this, please let us know and we will be glad to adjust our follow up date.
Hoping to hear from you soon.
Should there be no response, we will follow up after 3 business days.
Crisselle C
Hello Kreksoverzum,
We are sending this message to confirm that we received your reply via email.
We appreciate your effort in sending the requested information. We will continue to check this issue with our engineers and get back to you as soon as we heard form them but no later than 2-3 business days.
Crisselle C
Hello Kreksoverzum,
Good day!
Before we share the SSU logs to our engineers, kindly provide the additional information below as our initial findings based on the logs.
1.) We noticed that there is no Intel driver installed for Intel(R) PRO/1000 PT adapter on Windows 7 OS. Is it possible to extract the logs from original system with Ubuntu OS as there is no driver installed on your Windows 7 system?
You may also visit this link for Final-Release driver for Windows 7 OS
2.) Have you also tried installing the latest driver 3.8.4 from link below?
For Ubuntu OS
We will follow up after 3 business days in case we don't hear from you.
Crisselle C
Hello Kreksoverzum,
How are you doing?
We'd like to follow up the additional information that we are requesting for. In case you need more time on this, please let us know and we will be glad to adjust our follow up date.
Awaiting to hear from you.
Crisselle C
Yes, I'd like to have a little bit more time. Thank you for your support.
Hello Kreksoverzum,
Thank you for the reply.
Then, we will patiently wait for your update. To give you enough time on this, we will make another follow up after 3-5 business days.
Feel free to let us know if you have additional questions or clarifications.
Crisselle C
