Ethernet Products
5821 Discussions
Unable to install/compile E810 CQDA2 driver on CentOS 9
rp72
While trying make on ice-1.11.14
# make install
echo "*** The target kernel has CONFIG_MODULE_SIG_ALL enabled, but" ; echo "*** the signing key cannot be found. Module signing has been" ; echo "*** disabled for this build." ; make  ccflags-y="" -C "/lib/modules/5.14.0-295.el9.x86_64/source" CONFIG_ICE=m CONFIG_MODULE_SIG=n CONFIG_MODULE_SIG_ALL= M="/root/Downloads/ice-1.11.14/src"   NEED_AUX_BUS="0"  modules
make[1]: Entering directory '/usr/src/kernels/5.14.0-295.el9.x86_64'
  CC [M]  /root/Downloads/ice-1.11.14/src/ice_main.o
In file included from /root/Downloads/ice-1.11.14/src/kcompat.h:3351,
                 from /root/Downloads/ice-1.11.14/src/ice.h:7,
                 from /root/Downloads/ice-1.11.14/src/ice_main.c:8:
/root/Downloads/ice-1.11.14/src/kcompat_impl.h: In function ‘_kc_netif_napi_add’:
/root/Downloads/ice-1.11.14/src/kcompat_impl.h:1387:16: error: too many arguments to function ‘netif_napi_add’
 1387 |         return netif_napi_add(dev, napi, poll, NAPI_POLL_WEIGHT);
In file included from ./include/linux/etherdevice.h:21,
                 from /root/Downloads/ice-1.11.14/src/kcompat.h:16,
./include/linux/netdevice.h:2519:1: note: declared here
 2519 | netif_napi_add(struct net_device *dev, struct napi_struct *napi,
make[2]: *** [scripts/Makefile.build:321: /root/Downloads/ice-1.11.14/src/ice_main.o] Error 1
make[1]: *** [Makefile:1922: /root/Downloads/ice-1.11.14/src] Error 2
make[1]: Leaving directory '/usr/src/kernels/5.14.0-295.el9.x86_64'
make: *** [Makefile:149: all] Error 2
Upon trying to install the rpm for rhel9.1, causes below conflicts
# dnf install kmod-ice-1.11.14-1.rhel9.1.x86_64.rpm
Last metadata expiration check: 0:31:13 ago on Tue 11 Apr 2023 11:06:52 AM PDT.
Error:
 Problem: conflicting requests
  - nothing provides kernel(__SCK__tp_func_xdp_exception) = 0xc15ae5f5 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(__alloc_pages) = 0x26458776 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(__auxiliary_device_add) = 0x8961eeb0 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(__dev_kfree_skb_any) = 0x8d62db77 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(__dynamic_dev_dbg) = 0x2b6a5ee2 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(__dynamic_netdev_dbg) = 0x5fa262e0 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(__free_pages) = 0x7ddd045c needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(__hw_addr_sync_dev) = 0x84c17451 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(__hw_addr_unsync_dev) = 0xb05b216e needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(__napi_alloc_skb) = 0x5f802418 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(__napi_schedule) = 0xd950278d needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(__netif_napi_del) = 0x310d1afd needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(__page_frag_cache_drain) = 0xb6ccef70 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(__pci_register_driver) = 0x1cb89f6b needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(__pskb_pull_tail) = 0xc5c23ea2 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(__skb_flow_dissect) = 0xed0e9a0b needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(__skb_pad) = 0x16cd8a38 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(__tracepoint_xdp_exception) = 0xad42e583 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(_dev_err) = 0x3a3ec6c6 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(_dev_info) = 0xff4f021a needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(_dev_warn) = 0x1e5fac62 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(alloc_etherdev_mqs) = 0x665d1b75 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(auxiliary_device_init) = 0x00c852e7 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(boot_cpu_data) = 0x22892d67 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(bpf_dispatcher_xdp_func) = 0x6f8f674a needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(bpf_prog_put) = 0xa1b79421 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(bpf_trace_run1) = 0x283234f3 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(bpf_trace_run2) = 0x2b406f35 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(bpf_trace_run3) = 0x09ce4a38 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(bpf_warn_invalid_xdp_action) = 0xb05e54b3 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(build_skb) = 0x5c034c8f needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(call_netdevice_notifiers) = 0xa1d2cada needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(consume_skb) = 0x014a9f1b needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(convert_art_ns_to_tsc) = 0xb2c96edc needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(current_task) = 0xa9b5db44 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(dcb_getapp) = 0x535a6190 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(dcb_ieee_delapp) = 0xc6496dd5 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(dcb_ieee_setapp) = 0x68aabfb5 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(debugfs_create_dir) = 0x11b4f7a8 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(debugfs_create_file) = 0xa6202222 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(debugfs_remove) = 0x20033468 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(default_llseek) = 0x684b55b7 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(dev_change_flags) = 0x87b6dce7 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(dev_close) = 0xbdcab441 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(dev_driver_string) = 0xcdafdb2a needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(dev_mc_add_excl) = 0x70b9434c needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(dev_mc_del) = 0xb933719d needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(dev_open) = 0x8004c70c needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(dev_uc_add) = 0xbf43faef needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(dev_uc_add_excl) = 0xf134722b needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(dev_uc_del) = 0x246f556e needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(device_create_file) = 0xad907295 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(device_del) = 0x8a98d0b5 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(device_remove_file) = 0x260c0bfa needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(device_set_wakeup_enable) = 0xac4a0980 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(devlink_alloc_ns) = 0xdf8bd943 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(devlink_port_attrs_set) = 0xefff92f7 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(devlink_port_register) = 0xa23918fe needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(devlink_port_type_clear) = 0xd70db0e5 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(devlink_port_type_eth_set) = 0xd983a691 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(devlink_port_unregister) = 0xd86dfb8e needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(devm_add_action) = 0x5e1e4020 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(devm_free_irq) = 0x88e52ab2 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(devm_kasprintf) = 0xe5b5b0af needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(devm_kfree) = 0x92716ffa needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(devm_kmalloc) = 0xe9ad0580 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(devm_kmemdup) = 0x2aa8d785 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(devm_request_threaded_irq) = 0x2c740816 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(dma_map_page_attrs) = 0xe2dc579b needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(dma_set_coherent_mask) = 0x97c42987 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(dma_set_mask) = 0xf4110cd1 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(dma_sync_single_for_cpu) = 0x51b1550f needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(dma_sync_single_for_device) = 0x9980b0a6 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(dma_unmap_page_attrs) = 0xa41d1497 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(dmam_alloc_attrs) = 0x3e6787ac needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(dmam_free_coherent) = 0x371fe39c needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(dst_release) = 0xfa994855 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(eth_get_headlen) = 0x98601bb3 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(eth_type_trans) = 0x25c1aba0 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(eth_validate_addr) = 0xfc0d5980 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(ethtool_op_get_link) = 0xc3aa9108 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(ethtool_op_get_ts_info) = 0x7eb31781 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(event_triggers_call) = 0x06bb051c needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(firmware_request_nowarn) = 0xe46a464b needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(flow_block_cb_lookup) = 0x1baa95bf needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(flow_block_cb_setup_simple) = 0x4dd5fafe needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(flow_indr_block_cb_alloc) = 0x8b74b3b5 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(flow_indr_dev_register) = 0x31830af5 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(flow_indr_dev_unregister) = 0xc477cd7b needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(flow_keys_dissector) = 0xc9831ad7 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(flow_rule_match_basic) = 0x25484129 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(flow_rule_match_control) = 0x58f44ada needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(flow_rule_match_cvlan) = 0xfd0b2671 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(flow_rule_match_enc_control) = 0x0798db96 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(flow_rule_match_enc_ip) = 0xcfe9e2fe needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(flow_rule_match_enc_ipv4_addrs) = 0x48776fe6 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(flow_rule_match_enc_ipv6_addrs) = 0x272ff47a needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(flow_rule_match_enc_keyid) = 0xeeca4c69 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(flow_rule_match_enc_ports) = 0xd1985851 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(flow_rule_match_eth_addrs) = 0x8ed3155a needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(flow_rule_match_ip) = 0x85f1f157 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(flow_rule_match_ipv4_addrs) = 0xbdf78972 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(flow_rule_match_ipv6_addrs) = 0xe5b3cb63 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(flow_rule_match_ports) = 0x1e40d8a8 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(flow_rule_match_vlan) = 0x5aa0b86f needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(flush_workqueue) = 0x42160169 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(free_netdev) = 0x52c68cbc needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(get_device_system_crosststamp) = 0xcb0c3e7c needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(init_net) = 0x1d46e56e needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(ipv6_find_hdr) = 0x9c90a5b6 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(ipv6_skip_exthdr) = 0xde68a851 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(kmalloc_caches) = 0x5f73fb3c needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(kmem_cache_alloc_trace) = 0xa3cddcae needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(kobject_create_and_add) = 0x87a4b593 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(kobject_put) = 0xef863a86 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(kthread_cancel_delayed_work_sync) = 0xec2bc94a needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(kthread_cancel_work_sync) = 0x364a5a4d needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(kthread_create_worker) = 0x32520b59 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(kthread_destroy_worker) = 0x89dd03d0 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(kthread_queue_delayed_work) = 0x2b509f5a needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(kthread_queue_work) = 0x75bb5d97 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(metadata_dst_alloc) = 0x80198115 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(metadata_dst_free) = 0x6af29af4 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(module_layout) = 0xa7f1f8eb needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(napi_complete_done) = 0x40402bca needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(napi_consume_skb) = 0x10e9a3dc needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(napi_disable) = 0x284fd3bf needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(napi_enable) = 0xaf328093 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(napi_gro_receive) = 0x4bd5d8dd needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(napi_schedule_prep) = 0x76bae8ab needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(ndo_dflt_bridge_getlink) = 0x089345b5 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(netdev_bind_sb_channel_queue) = 0xe7a79ec8 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(netdev_err) = 0xc66472cf needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(netdev_info) = 0xa71c2c40 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(netdev_master_upper_dev_get) = 0xea8eeac4 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(netdev_master_upper_dev_get_rcu) = 0xc689f989 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(netdev_pick_tx) = 0xab0e64eb needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(netdev_reset_tc) = 0x8849ff8a needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(netdev_set_num_tc) = 0xd82a15a6 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(netdev_set_sb_channel) = 0x7fc0820d needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(netdev_set_tc_queue) = 0x9d6a1782 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(netdev_state_change) = 0x21794fd2 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(netdev_unbind_sb_channel) = 0x71b0e388 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(netdev_warn) = 0xfe96cfed needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(netif_carrier_off) = 0x14111c62 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(netif_carrier_on) = 0x96781ba1 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(netif_napi_add) = 0xec77a489 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(netif_schedule_queue) = 0xe191e05f needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(netif_set_real_num_rx_queues) = 0x8379688b needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(netif_set_real_num_tx_queues) = 0xa1e2fa4b needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(netif_set_xps_queue) = 0x2813f1cd needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(netif_tx_stop_all_queues) = 0x13392855 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(netif_tx_wake_queue) = 0x24e11830 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(param_ops_int) = 0xaad18ecd needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(param_ops_ulong) = 0xd7978376 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(param_ops_ushort) = 0x6cfb7e3f needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(pci_aer_clear_nonfatal_status) = 0x254f8d5e needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(pci_alloc_irq_vectors_affinity) = 0xbfc4f760 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(pci_device_is_present) = 0xd97c17c8 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(pci_disable_device) = 0x0921c2a1 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(pci_disable_pcie_error_reporting) = 0xf4167337 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(pci_disable_sriov) = 0xae1adbfa needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(pci_enable_device) = 0x380fa45d needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(pci_enable_device_mem) = 0x74ebcbd1 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(pci_enable_pcie_error_reporting) = 0x717d4b61 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(pci_enable_sriov) = 0x68c478f7 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(pci_find_ext_capability) = 0xce3f4b59 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(pci_free_irq_vectors) = 0x81ccc3d2 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(pci_get_device) = 0x7e3c03c5 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(pci_get_dsn) = 0xa618e55a needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(pci_irq_vector) = 0x3dd350d3 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(pci_num_vf) = 0xbf36cc3e needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(pci_read_config_byte) = 0x595813a6 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(pci_read_config_word) = 0x3911c65c needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(pci_release_selected_regions) = 0x7a3abda2 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(pci_request_selected_regions) = 0xfab14d9f needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(pci_restore_msi_state) = 0x3b235888 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(pci_restore_state) = 0x24bbcb8b needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(pci_save_state) = 0xfd2da512 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(pci_select_bars) = 0x1191f7a3 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(pci_set_master) = 0x2f6d2bb5 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(pci_set_power_state) = 0x54621869 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(pci_unregister_driver) = 0xa972d633 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(pci_vfs_assigned) = 0x6bdb5a77 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(pci_wait_for_pending_transaction) = 0x1bd1557b needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(pci_wake_from_d3) = 0x2464b789 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(pcie_print_link_status) = 0x26df835b needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(perf_trace_run_bpf_submit) = 0xa3b52f89 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(pldmfw_flash_image) = 0xb9c4df51 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(pldmfw_op_pci_match_record) = 0x36c7e835 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(printk) = 0xc5850110 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(pskb_expand_head) = 0x0d526b2b needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(ptp_clock_event) = 0xe7d77369 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(ptp_clock_index) = 0x3876beca needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(ptp_clock_register) = 0x0ed9b290 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(ptp_clock_unregister) = 0xb77a6063 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(put_device) = 0xb88a69a3 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(register_netdev) = 0xba3ff097 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(request_firmware) = 0x4f79928e needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(rps_may_expire_flow) = 0xce7e714e needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(simple_open) = 0xf9fc90f3 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(skb_add_rx_frag) = 0x21ea980a needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(skb_checksum_help) = 0x08d53501 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(skb_clone_tx_timestamp) = 0x5b57e627 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(skb_copy_bits) = 0x632061f3 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(skb_tstamp_tx) = 0xc6a9499d needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(softnet_data) = 0x3bf76a4e needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(sysfs_create_file_ns) = 0xa9602740 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(sysfs_remove_file_ns) = 0x3157184b needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(trace_event_buffer_commit) = 0x353312e1 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(trace_event_buffer_reserve) = 0x680ab4cd needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(trace_event_ignore_this_pid) = 0xc0b530c7 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(trace_event_printf) = 0x3c3a0f8b needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(trace_event_raw_init) = 0x0739d5a0 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(trace_event_reg) = 0x4780963a needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(trace_raw_output_prep) = 0xce46eeeb needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(unregister_netdev) = 0x01d13501 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(vlan_dev_real_dev) = 0x898ba93b needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(vlan_dev_vlan_id) = 0xb59d1f41 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(vlan_dev_vlan_proto) = 0xfa82b061 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(xdp_convert_zc_to_xdp_frame) = 0xcdb7b8cd needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(xdp_do_redirect) = 0x635f6fef needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(xdp_master_redirect) = 0xd895cc1b needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(xdp_return_frame) = 0x5b1c3ac9 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(xdp_return_frame_rx_napi) = 0x4742580d needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(xdp_rxq_info_is_reg) = 0x8966ea6e needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(xdp_rxq_info_reg) = 0xc5f644e9 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(xdp_rxq_info_reg_mem_model) = 0xcabfedb2 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(xdp_rxq_info_unreg) = 0x0d8f96fc needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(xdp_rxq_info_unreg_mem_model) = 0x610cb9e1 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(xp_alloc) = 0xa0815c99 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(xp_dma_map) = 0x0198092e needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(xp_dma_sync_for_cpu_slow) = 0x0cac6528 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(xp_dma_sync_for_device_slow) = 0xe91374d9 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(xp_dma_unmap) = 0xb4f7ca78 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(xp_free) = 0xa353e08d needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(xp_raw_get_dma) = 0x0eb88c7f needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(xp_set_rxq_info) = 0x86b2db4e needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(xsk_clear_rx_need_wakeup) = 0xbfafec65 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(xsk_get_pool_from_qid) = 0xe07920e3 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(xsk_set_rx_need_wakeup) = 0xec909449 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(xsk_set_tx_need_wakeup) = 0xae41f938 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(xsk_tx_completed) = 0x5205b281 needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(xsk_tx_peek_desc) = 0xe67282ce needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(xsk_tx_release) = 0xb016016f needed by kmod-ice-1.11.14-1.x86_64
  - nothing provides kernel(xsk_uses_need_wakeup) = 0xfd4cbbc6 needed by kmod-ice-1.11.14-1.x86_64
(try to add '--skip-broken' to skip uninstallable packages or '--nobest' to use not only best candidate packages)
