Ethernet Products
5608 Discussions
Unable to load driver for 800 series Network Adapter
chomar
I have a problem to load driver for Intel Corporation Device 1592. I downloaded and tried ice-1.5.8 and ice-1.6.4 , but I have the same issue:
Build steps:
cd ice-1.x.x/src
make
insmod ice.ko
user@ubuntu:~/ice-1.6.4/src$ sudo dmesg
[ 3639.799117] ice: Unknown symbol devlink_port_type_eth_set (err 0)
[ 3639.799188] ice: Unknown symbol devlink_unregister (err 0)
[ 3639.799482] ice: Unknown symbol devlink_register (err 0)
[ 3639.799505] ice: Unknown symbol devlink_port_type_clear (err 0)
[ 3639.799536] ice: Unknown symbol devlink_free (err 0)
[ 3639.799883] ice: Unknown symbol devlink_port_unregister (err 0)
[ 3639.800240] ice: Unknown symbol devlink_alloc (err 0)
[ 3639.800409] ice: Unknown symbol devlink_port_register (err 0)
user@ubuntu:~/ice-1.6.4/src$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 18.04.4 LTS
Release: 18.04
Codename: bionic
Caguicla_Intel
Hello chomar,
We are sorry to hear that you are unable to load driver for 800 series Network Adapter. Before we proceed checking your query, kindly confirm if your are representing an End-Customer or is this for personal use?
Awaiting to hear from you soon.
We will follow up after 3 business days in case we don't receive a response.
Crisselle C.
Intel® Customer Support
chomar
Hi.
I forgot command "modprobe ice" before installing driver. We can close this topic.
AlexWeaverLabs
I did the "modprobe ice" and i get the following error:
modprobe: ERROR: could not insert 'ice': Unknown symbol in module, or unknown parameter (see dmesg)
I check dmesg and I get the following
[23128.128209] ice: Unknown symbol gnss_insert_raw (err -2)
[23128.128793] ice: Unknown symbol gnss_allocate_device (err -2)
[23128.128875] ice: Unknown symbol gnss_deregister_device (err -2)
[23128.128948] ice: Unknown symbol gnss_register_device (err -2)
[23128.128985] ice: Unknown symbol gnss_put_device (err -2)
Did you face the same error?
Caguicla_Intel
Hello chomar,
Thank you for the update.
We will now proceed with closure as per your request. If you may have any other inquiry in the future, just feel free to post a new question as this thread will no longer be monitored.
May you have a great day and stay safe!
Crisselle C.
