Steps I have taken so far:
- Verified IOMMU and SR-IOV are enabled in BIOS
- Checked with lspci -vvv -s <PCI-ID> but SR-IOV is missing
- Successfully see SR-IOV on another adapter using the same driver
- Manually installed the latest i40e driver from Intel, but no change
- Reloaded the driver and rescanned the PCI bus.
Server :
- Ampere Altra [ GNU/Linux 5.15.0-88-generic Ubuntu 22.04.3 LTS (Jammy Jellyfish) aarch64 ]
- Dell-AMD EPYC 9654 [ GNU/Linux 5.15.0-88-generic Ubuntu "22.04.3 LTS (Jammy Jellyfish) x86_64]
I see the same issue in both servers
Lspci details: X710/X557-AT
Ethernet controller: Intel Corporation Ethernet Controller X710/X557-AT 10GBASE-T (rev 02)
Subsystem: Intel Corporation Ethernet Converged Network Adapter X710-T
Flags: bus master, fast devsel, latency 0, IRQ 1467, NUMA node 1, IOMMU group 60
Memory at 90000000 (64-bit, prefetchable) [size=16M]
Memory at 94000000 (64-bit, prefetchable) [size=32K]
Expansion ROM at 94100000 [disabled] [size=512K]
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Capabilities: [70] MSI-X: Enable+ Count=129 Masked-
Capabilities: [a0] Express Endpoint, MSI 00
Capabilities: [e0] Vital Product Data
Capabilities: [100] Advanced Error Reporting
Capabilities: [140] Device Serial Number b0-25-0e-ff-ff-6f-7c-50
Capabilities: [150] Alternative Routing-ID Interpretation (ARI)
Capabilities: [1a0] Transaction Processing Hints
Capabilities: [1b0] Access Control Services
Capabilities: [1d0] Secondary PCI Express
Kernel driver in use: i40e
Kernel modules: i40e
lspci : X710 SFP+ [ lists the SR-IOV ]
Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 02)
Subsystem: Intel Corporation Ethernet Converged Network Adapter X710-2
Flags: bus master, fast devsel, latency 0, IRQ 77, NUMA node 0, IOMMU group 21
Memory at c4000000 (64-bit, prefetchable) [size=8M]
Memory at c5800000 (64-bit, prefetchable) [size=32K]
Expansion ROM at c5b00000 [disabled] [size=512K]
Capabilities: [140] Device Serial Number 66-40-a8-ff-ff-ba-e2-90
Capabilities: [160] Single Root I/O Virtualization (SR-IOV)
Hello pmdsouza,
For us to further check the issue, please provide the following details.
1) Are you using a PCIe X710 or onboard?
2) What is the brand and model of your system or motherboard?
3) If you are using a PCIe card, can you send photos of the card on both sides for us to validate if the card is not an OEM unit?
Please also check whether the VT-d option is enabled in the BIOS and configured for the NIC in question. Example is as per below, but it depends on your system.
Go to System BIOS >> Device Settings >> Ethernet Converged Network Adapter X710 >> Device Level Configuration >> Virtualization Mode = SR-IOV
Besides that, please check the list of Intel Ethernet Adapters and Intel Ethernet Controllers support SR-IOV below:
Intel® Ethernet 800 Series
- Intel® Ethernet Network Adapter E810 (All Product SKUs)
Intel® Ethernet Network Adapter X722 Series
- Intel® Ethernet Network Adapter X722-DA2
- Intel® Ethernet Network Adapter X722-DA4
Intel® Ethernet Converged Network Adapter XL710 Series
- Intel® Ethernet Converged Network Adapter XL710-QDA1
- Intel® Ethernet Converged Network Adapter XL710-QDA2
- Intel® Ethernet Converged Network Adapter XL710-QDA1 for OCP
- Intel® Ethernet Converged Network Adapter XL710-QDA2 for OCP
Intel® Ethernet Network Adapter XXV710 Series
- Intel® Ethernet Network Adapter XXV710-DA1
- Intel® Ethernet Network Adapter XXV710-DA2
- Intel® Ethernet Network Adapter XXV710-DA1 for OCP
- Intel® Ethernet Network Adapter XXV710-DA2 for OCP
Intel® Ethernet Converged Network Adapter X710 Series
- Intel® Ethernet Converged Network Adapter X710-DA2
- Intel® Ethernet Converged Network Adapter X710-DA4
- Intel® Ethernet Converged Network Adapter X710-T4
- Intel® Ethernet Controller X710/X557-AT 10GBASE-T
Intel® Ethernet Connection X722
- Intel® Ethernet Connection X722 for 10GBASE-T
- Intel® Ethernet Connection X722 for 10GbE backplane
- Intel® Ethernet Connection X722 for 10GbE QSFP+
- Intel® Ethernet Connection X722 for 10GbE SFP+
Intel® Ethernet Converged Network Adapter X550
- Intel® Ethernet Converged Network Adapter X550-T1
- Intel® Ethernet Converged Network Adapter X550-T2
Intel® Ethernet Converged Network Adapter X540
- Intel® Ethernet Converged Network Adapter X540-T1
- Intel® Ethernet Converged Network Adapter X540-T2
Intel® 82599 10 Gigabit Ethernet Controller
- Intel® Ethernet 82599EB 10 Gigabit Ethernet Controller
- Intel® Ethernet 82599ES 10 Gigabit Ethernet Controller
- Intel® Ethernet 82599EN 10 Gigabit Ethernet Controller
Intel® Ethernet Converged Network Adapter X520
- Intel® Ethernet Converged Network Adapter X520-DA2
- Intel® Ethernet Converged Network Adapter X520-SR1
- Intel® Ethernet Converged Network Adapter X520-SR2
- Intel® Ethernet Converged Network Adapter X520-LR1
- Intel® Ethernet Converged Network Adapter X520-T2
Intel® Ethernet Controller I350
- Intel® Ethernet Controller I350-AM4
- Intel® Ethernet Controller I350-AM2
- Intel® Ethernet Controller I350-BT2
Intel® Ethernet Server Adapter I350
- Intel® Ethernet Server Adapter I350-T2
- Intel® Ethernet Server Adapter I350-T4
- Intel® Ethernet Server Adapter I350-F2
- Intel® Ethernet Server Adapter I350-F4
You can go through the following link for more information: https://www.intel.com/content/www/us/en/support/articles/000005722/ethernet-products.html
Thank You & Best Regards,
Ragulan_Intel
Hello pmdsouza,
Hope this message finds you well.
This is a gentle follow up for this thread, we would appreciate if you could let us know if you had the chance to review the POA provided previously. If yes, please let us know the outcome.
Thank you & Best regards,
Ragulan_Intel
Hi Ragulan_Intel,
Please find my reply inline :
- PCIe X710
- Server : Dell EMC PowerEdge XR12 , Baseboard Manufacturer: Dell Inc [ Product Name: 07GGDG Version: A00] CPU : Intel(R) Xeon(R) Gold 6338N CPU @ 2.20GHz
I am using intelNIC with pulsejack ICM, I am yet to get the exact photos of the card, attached is the reference picture
Hi pmdsouza,
Greetings!
Thank you for sharing the details. Please share exact photos of the NIC card at your convenience so we can validate further.
Sreelakshmi
Hi pmdsouza,
Good day,
This is related to your enquiries above, I would like to check if the issue has resolved?
If you have any questions or clarifications, please let me know.
Sazzy_Intel
Hi pmdsouza,
Good day,
This is a gentle follow up on this thread, we would appreciate if you could let us know whether you had the chance to obtain the pictures as requested?
Ragulan_Intel
Hi pmdsouza,
Greetings!
Kindly note that as we have not received any response from our previous follow-ups, we will be closing this request.
You may receive an invitation to take a survey in a few days. We value your feedback and look forward to hearing about your support experience.
Ragulan_Intel
