Ethernet Products
4974 Discussions
Unable to update Intel x710-DA2 firmware to 6.01 on UCS C220M4 w/ VMware 6.5U2
MDirk
I upgrade the 10G NIC via Cisco HUU v4.01a but it still reports version 5.05. I then ran the Intel NVM update tool for VMware 6.5 and it reports Update not available. What can I attempt next, the NIC is currently dropping random traffic.
Hello Mikedirks,
Thank you for posting in Intel Wired Ethernet Communities. Please confirm that the X710-DA2 Ethernet adapter is a retail Intel adapter. If this is a Cisco OEM adapter the NVM update utility is not designed to work with it. Check with Cisco support for any firmware updates if this is the case.
To further investigate this issue please provide the following:
esxcli network nic get -n output
Dmesg output
vmkernel.log
If you have any questions please do not hesitate to ask.
Daniel D
Hello Mikedirks,
Dmesg output
vmkernel.log
Daniel D
Hello Mikedirks,
Please let us know if this is a retail Intel adapter. If you no longer need assistance, or already found help from the OEM please inform us.
Daniel D
Hello Mikedirks,
If you have any questions please let us know.
Daniel D
MDirk
Cisco made an unlocked firmware and used the Intel firmware update tool to install it. The have had several requested for firmware 6.01 so it suppose to be added to their UCS HUU tool with the next update.
Thanks for your help.
Michael
Hello Mikedirks,
Thank you for the update. Hope the firmware update is released soon. If you have any other questions please do not hesitate to contact us.
Daniel D
