Ethernet Products
4872 Discussions
Unable to update firmware on Intel X550-T1
eandersson
I bought a T1 and a T2. I installed the T2 and upgraded the firmware without an issue, and wanted to do the same on the T1 that I installed on my workstation, but for some reason it does not allow me to update. I tried both on Windows and Linux.
When running the tool it gives me the following.
01) Intel(R) Ethernet Controller X550-T2 0.01(0.01) 1563 00:004 Update not available
mint@mint:~$ sudo ethtool -i enp4s0
driver: ixgbe
version: 5.1.0-k
firmware-version: 0x80000391
expansion-rom-version:
bus-info: 0000:04:00.0
eandersson
I figured it out. I was able to download a really old version of the firmware v1.86 and that allowed me to update from v0.01. Once I was on v1.86 I was able to update to v3.10.
eandersson
Caguicla_Intel
Hello eandersson,
We are glad to hear that you are now able to update the firmware to latest version. With this, we would like to know if you have any other assistance needed on this matter. If yes, please let us know and we will be glad to check on it. If none, kindly advise if we can now close this request.
Hoping to hear from you soon.
Should there be no response from you, I’ll make sure to reach out after 3 business days.
Crisselle C
Intel® Customer Support
eandersson
Feel free to close this. Hopefully it will help someone else stuck in the same boat.
Joose
Dear Caguicla:
We have same problem,but we can't update from v.1.86,Could you send Non-Volatile Memory (NVM) Update Utility for Intel® Ethernet Adapters 550 Series—Windows* v.1.55 to me.
Look forward you reply,tks!
Quote:
C:\X550\Winx64>nvmupdatew64e.exe
Intel(R) Ethernet NVM Update Tool
NVMUpdate version 1.32.13.0
Copyright (C) 2013 - 2018 Intel Corporation.
WARNING: To avoid damage to your device, do not stop the update or reboot or power off the system during this update.
Inventory in progress. Please wait [+.........]
Num Description Ver. DevId S:B Status
01) Intel(R) Ethernet Connection (2) I219-LM 15B7 00:000 Not supported
02) Intel(R) Ethernet Converged Network 0.01 15D1 00:002 Update not
Adapter X550-T1 available
Tool execution completed with the following status: Device not found.
Press any key to exit.
Caguicla_Intel
Hello eandersson,
Thank you for the swift response.
We highly appreciate your effort in sharing the issue resolution on this thread. This is indeed helpful for the other users having the same issue.
We will now close this request. Thank you again for your time and cooperation. If you need any additional information, please submit a new question as this thread will no longer being monitored.
May you have a great day!
Crisselle C
