Ethernet Products
5742 Discussions
Unpgrade Intel Driver on FedoraCoreOS
Abdul3
Greetings,
I am seeking guidance on updating the Intel NIC Driver to the latest version on a Fedora CoreOS machine. Despite thorough research, I couldn't find specific instructions tailored to Fedora CoreOS for this task.
Here are the details of the NIC :
  • NIC: Intel Corporation Ethernet Controller XXV710 for 25GbE SFP28 (rev 02)
  • Current Driver Version: i40e (5.14.0-284.48.1.rt14.333.el9_2)
  • Firmware Version: 9.40 0x8000e9b0 22.5.7
While the firmware version is up to date, the driver version requires an update. I aim to install the latest driver version available from the Intel website, accessible via this link: Intel Network Adapter Driver for PCIe 40 Gigabit Ethernet Network Connections under Linux.
For context, on Ubuntu, I successfully updated the driver using the following
ubuntu@bm5:~$ sudo ethtool -i ens2f0
driver: i40e
version: 2.24.6
firmware-version: 9.40 0x8000e9b0 22.5.7
expansion-rom-version: bus-info: 0000:b3:00.0
Note:
there are no available .repo files, in case I need to install something, please suggest the repo for the same I will be using.
/etc/yum.repos.d/
Looking forward to hearing you back!
Thanks!
Md Rouf
CarlosAM_INTEL
Hello, @Abdul3:
We received your consultations, but we want to address the following questions to understand them:
Could you please confirm if the device related to this situation has been designed by you or a third-party developer? In case it is a third-party device, please let us know the name of the manufacturer and the part number of the device.
Could you please confirm if this situation is related to an Intel Ethernet Controller, NIC card, or adding card? Please mention the name of the manufacturer and part number.
Where do you purchase the device related to your requests?
We are waiting for your clarification.
@CarlosAM_INTEL.
Abdul3
It's from Intel, and the query is related to upgrading the Driver version to the latest on FedoraCoreOS as already mentioned!
lspci -vv -s b3:00.0 | grep "Part number" -A 3
[PN] Part number: 00M95
[MN] Manufacture ID: 1028
[V1] Vendor specific: DSV1028VPDR.VER2.1
[V3] Vendor specific: DTINIC
[V7] Vendor specific: NMVIntel Corp
Ethernet controller: Intel Corporation Ethernet Controller XXV710 for 25GbE SFP28 (rev 02)
Subsystem: Intel Corporation Ethernet 25G 2P XXV710 Adapter
Rouf.
CarlosAM_INTEL
Hello, @Abdul3:
Thanks for your reply.
Based on your previous communication, could you please confirm that the device related to this forum is the one shown on the following website?
https://www.intel.com/content/www/us/en/products/details/ethernet/700-network-adapters/xxv710-network-adapters/products.html
@CarlosAM_INTEL.
Abdul3
Hi @CarlosAM_INTEL
Thank you for the quick response, yes, it's the same and I need the instruction on how to upgrade its driver on FedoraCoreOS.
Warm Regards
Rouf
CarlosAM_INTEL
Hello, @Abdul3:
Thanks for your clarification.
Your consultation will be transferred to the proper channel to help you with your consultation related to the Intel® Ethernet Network Adapter XXV710.
The team in charge of this channel will contact you as soon as possible.
@CarlosAM_INTEL.
Abdul3
@CarlosAM_INTEL I'm yet to receive any updates. Could you please let me know if i need to add any tags?
Abdul3
A gentle follow-up!
Any updates on this?
Md Rouf
