Ethernet Products
5527 Discussions
Update ice driver to support kernel 6.8 (VFIO migration protocol v2)
abhinavms
ice-vfio-pci.ko is not getting generated in kernel 6.8 as VFIO migration protocol v1 is deprecated and the support for VFIO migration protocol v2 is not yet added
Bug description
For ice-vfio-pci generation, HAVE_LMV1_SUPPORT has to be present in the generated kcompat_generated_defs.h file.
HAVE_LMV1_SUPPORT is added if macro VFIO_REGION_TYPE_MIGRATION is defined under include/uapi/linux/vfio.h in the kernel code
However the migration protocol v1 was depreciated. Therefore VFIO_REGION_TYPE_MIGRATION does not exist anymore.
Reference:
Driver Tag/Commit
https://github.com/intel/ethernet-linux-ice/releases/tag/v1.15.4
Custom Code
No
Reproduction steps
  1. Pull latest 6.8 kernel from Ubuntu(https://git.launchpad.net/~ubuntu-kernel/ubuntu/+source/linux/+git/noble/tag/?h=Ubuntu-6.8.0-38.38) or the latest rc tag from Linux tree (https://github.com/torvalds/linux/tree/v6.8-rc7)
  2. Try to compile with 1.15.4
  3. Notice that ice-vfio-pci.ko is not generated
Expected Behavior
ice-vfio-pci.ko to be generated
Actual Behavior
Relevant log output
None as vfio is not generated.
But if you try to use the depreciated VFIO_REGION_TYPE_MIGRATION_DEPRECATED & VFIO_REGION_SUBTYPE_MIGRATION_DEPRECATED, you get another set of errors
/home/ubuntu/ice/ice-1.15.4/src/ice_vfio_pci.c: In function ‘ice_vfio_pci_set_device_state’:
/home/ubuntu/ice/ice-1.15.4/src/ice_vfio_pci.c:254:42: error: ‘VFIO_DEVICE_STATE_SAVING’ undeclared (first use in this function); did you mean ‘VFIO_DEVICE_STATE_V1_SAVING’?
  254 |         case VFIO_DEVICE_STATE_RUNNING | VFIO_DEVICE_STATE_SAVING:
/home/ubuntu/ice/ice-1.15.4/src/ice_vfio_pci.c:254:42: note: each undeclared identifier is reported only once for each function it appears in
/home/ubuntu/ice/ice-1.15.4/src/ice_vfio_pci.c: In function ‘ice_vfio_pci_mig_rw_data_size’:
/home/ubuntu/ice/ice-1.15.4/src/ice_vfio_pci.c:450:47: error: ‘VFIO_DEVICE_STATE_SAVING’ undeclared (first use in this function); did you mean ‘VFIO_DEVICE_STATE_V1_SAVING’?
  450 |                 if (mig_info->device_state != VFIO_DEVICE_STATE_SAVING)
/home/ubuntu/ice/ice-1.15.4/src/ice_vfio_pci.c: In function ‘ice_vfio_group_notifier’:
/home/ubuntu/ice/ice-1.15.4/src/ice_vfio_pci.c:557:23: error: ‘VFIO_GROUP_NOTIFY_SET_KVM’ undeclared (first use in this function)
  557 |         if (action == VFIO_GROUP_NOTIFY_SET_KVM)
/home/ubuntu/ice/ice-1.15.4/src/ice_vfio_pci.c: In function ‘ice_vfio_migration_init’:
/home/ubuntu/ice/ice-1.15.4/src/ice_vfio_pci.c:606:18: error: ‘VFIO_GROUP_NOTIFY_SET_KVM’ undeclared (first use in this function)
  606 |         events = VFIO_GROUP_NOTIFY_SET_KVM;
/home/ubuntu/ice/ice-1.15.4/src/ice_vfio_pci.c:607:15: error: implicit declaration of function ‘vfio_register_notifier’; did you mean ‘bus_register_notifier’? [-Werror=implicit-function-declaration]
  607 |         ret = vfio_register_notifier(dev, VFIO_GROUP_NOTIFY, &events,
/home/ubuntu/ice/ice-1.15.4/src/ice_vfio_pci.c:607:43: error: ‘VFIO_GROUP_NOTIFY’ undeclared (first use in this function)
/home/ubuntu/ice/ice-1.15.4/src/ice_vfio_pci.c:615:15: error: implicit declaration of function ‘vfio_pci_register_dev_region’; did you mean ‘vfio_pci_core_register_dev_region’? [-Werror=implicit-function-declaration]
  615 |         ret = vfio_pci_register_dev_region(&ice_vdev->core_device,
/home/ubuntu/ice/ice-1.15.4/src/ice_vfio_pci.c:630:9: error: implicit declaration of function ‘vfio_unregister_notifier’; did you mean ‘bus_unregister_notifier’? [-Werror=implicit-function-declaration]
  630 |         vfio_unregister_notifier(dev, VFIO_GROUP_NOTIFY,
/home/ubuntu/ice/ice-1.15.4/src/ice_vfio_pci.c: In function ‘ice_vfio_migration_uninit’:
/home/ubuntu/ice/ice-1.15.4/src/ice_vfio_pci.c:649:39: error: ‘VFIO_GROUP_NOTIFY’ undeclared (first use in this function)
  649 |         vfio_unregister_notifier(dev, VFIO_GROUP_NOTIFY,
/home/ubuntu/ice/ice-1.15.4/src/ice_vfio_pci.c: In function ‘ice_vfio_pci_probe’:
/home/ubuntu/ice/ice-1.15.4/src/ice_vfio_pci.c:728:9: error: implicit declaration of function ‘vfio_pci_core_init_device’; did you mean ‘vfio_pci_core_init_dev’? [-Werror=implicit-function-declaration]
  728 |         vfio_pci_core_init_device(&ice_vdev->core_device, pdev,
/home/ubuntu/ice/ice-1.15.4/src/ice_vfio_pci.c:740:9: error: implicit declaration of function ‘vfio_pci_core_uninit_device’; did you mean ‘vfio_pci_core_init_dev’? [-Werror=implicit-function-declaration]
  740 |         vfio_pci_core_uninit_device(&ice_vdev->core_device);
cc1: some warnings being treated as errors
All these error as because of migration protocol v1 depreciation. For example
VFIO_DEVICE_STATE_RUNNING does not exist anymore.
Reference: https://lore.kernel.org/all/20220224142024.147653-10-yishaih@nvidia.com/
Any idea when the new support will be added?
Akshaya1
Hi abhinavms,
Thank you for posting in the Intel Community. We sincerely apologize for the delay in our response. We have received your concern and would like to assure you that assisting you is our top priority.
Could you kindly let us know if the issue has been resolved, or if you require further assistance from us? Your prompt response will greatly help us in diagnosing and resolving the issue as quickly as possible.
We appreciate your patience and understanding, and we look forward to hearing from you soon.
Akshaya
Akshaya1
Hi abhinavms,
Greetings from Intel!
This is a reminder mail regarding the issue you reported to us.
We're eager to ensure a swift resolution and would appreciate any updates or additional information you can provide.
Akshaya
Akshaya1
Hi abhinavms,
Thank you for contacting Intel.
This is the second follow-up regarding the reported issue. We're eager to ensure a swift resolution and would appreciate any updates or additional information you can provide.
If we don't hear back from you soon, we'll assume the issue has been resolved and will proceed to close the case.
Please feel free to respond to this email at your earliest convenience.
Akshaya
Akshaya1
Hi abhinavms,
This is the third follow-up regarding the reported issue. We're committed to ensuring a swift resolution and would greatly appreciate any updates or additional information you can provide.
As we have not heard back from you, we'll assume the issue has been resolved and will proceed to close the case.
Akshaya
