Ethernet Products
5610 Discussions
Use SGMII interface on 82599ES NIC
JQuér
I have a PC with the 82599ES NIC and the TE 2127931-1 SFP+ transceiver to allow a 10Gb connection.
For my project, I need to use one of the port of the NIC with the SGMII interface instead of the XAUI one in order to have a 1Gb connection.
From the NIC datasheet (https://www.intel.com/content/www/us/en/embedded/products/networking/82599-10-gbe-controller-datasheet.html Intel® 82599 10 Gigabit Ethernet Controller: Datasheet), it seems that it can be done but I can't succeed to make it work.
Indeed, when I use ethtool, I have the following output:
Supported ports: [ FIBRE ]
Supported link modes: 10000baseT/Full
Supported pause frame use: Symmetric
Supports auto-negotiation: No
Advertised link modes: 10000baseT/Full
Advertised pause frame use: Symmetric
Advertised auto-negotiation: No
Speed: 10000Mb/s
Duplex: Full
Port: Direct Attach Copper
PHYAD: 0
Transceiver: internal
Auto-negotiation: off
Supports Wake-on: d
Wake-on: d
Current message level: 0x00000007 (7)
drv probe link
Link detected: yes
As you can see, there is no 1Gb speed in the supported mode.
Can somebody tell me what I am missing and what should I do to use the SGMII interface ? (note that the port with the 10Gb connection works as expected)
Julien
Hi JulienQ,
Thank you for posting in Wired Communities. With regards to your inquiry, please at our embedded support forum for them to better assist you.
https://embedded.communities.intel.com/community/en
Sharon T
