Ethernet Products
4535 Discussions
Use of both ports of a single network card ( X710 or 82599ES ) causes slow thoughtput
fYama
Hi
I have some servers ( they all have 2 cards ( x710 or 82599ES ) )
If I use both ports ( for a very intensive service ( a lot of small packets )) I get a very low throutput.
If I try the same, but using one port of each card, all work fine.
the pcie bus is "PCI-Express: Speed 5.0GT/s Width x8"
also, I got the message saying "PCI-Express bandwidth available for this device may be insufficient for optimal performance."
but afaik 5*8 is bandwidth enough for a dual 10gb, I'm right?
here is the output out lspci -vvvv
43:00.1 Ethernet controller: Intel Corporation 82599ES 10-Gigabit SFI/SFP+ Network Connection (rev 01)
Subsystem: Hewlett-Packard Company Ethernet 10Gb 2-port 560SFP+ Adapter
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 203
Region 0: Memory at fb300000 (64-bit, non-prefetchable) [size=1M]
Region 2: I/O ports at ece0 [size=32]
Region 4: Memory at fb1fc000 (64-bit, non-prefetchable) [size=16K]
Expansion ROM at d0000000 [disabled] [size=512K]
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=1 PME-
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Address: 0000000000000000 Data: 0000
Masking: 00000000 Pending: 00000000
Capabilities: [70] MSI-X: Enable+ Count=64 Masked-
Vector table: BAR=4 offset=00000000
PBA: BAR=4 offset=00002000
Capabilities: [a0] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0.000W
DevCtl: Report errors: Correctable- Non-Fatal+ Fatal+ Unsupported+
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+ FLReset-
MaxPayload 256 bytes, MaxReadReq 512 bytes
DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr+ TransPend-
LnkCap: Port #0, Speed 5GT/s, Width x8, ASPM L0s, Exit Latency L0s unlimited, L1 <8us
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 5GT/s, Width x8, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR-, OBFF Not Supported
DevCtl2: Completion Timeout: 65ms to 210ms, TimeoutDis-, LTR-, OBFF Disabled
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [e0] Vital Product Data
Product Name: HP Ethernet 10Gb 2-port 560SFP+ Adapter
Read-only fields:
[PN] Part number: 665247-001
[EC] Engineering changes: B-5317
[SN] Serial number: MYI33105FB
[V0] Vendor specific: 11W/8W PCIeG2x8 2p 10Gb SFP+ Intel 82599
[V2] Vendor specific: 5331
[V4] Vendor specific: 38EAA7902738
[V5] Vendor specific: 0B
[RV] Reserved: checksum good, 0 byte(s) reserved
Read/write fields:
[V1] Vendor specific: 00.00.00
[V3] Vendor specific: 2.7.110
[V6] Vendor specific: 2.2.02
[YA] Asset tag: N/A
[YB] System specific: xxxxxxxxxxxxxxxx
[YC] System specific: xxxxxxxxxxxxxxxx
End
Capabilities: [100 v1] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt+ UnxCmplt+ RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES- TLP+ FCP+ CmpltTO+ CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC+ UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
CEMsk: RxErr+ BadTLP+ BadDLLP+ Rollover+ Timeout+ NonFatalErr+
AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
Capabilities: [140 v1] Device Serial Number 38-ea-a7-ff-ff-90-27-38
Capabilities: [150 v1] Alternative Routing-ID Interpretation (ARI)
ARICap: MFVC- ACS-, Next Function: 0
ARICtl: MFVC- ACS-, Function Group: 0
Capabilities: [160 v1] Single Root I/O Virtualization (SR-IOV)
IOVCap: Migration-, Interrupt Message Number: 000
IOVCtl: Enable- Migration- Interrupt- MSE- ARIHierarchy-
IOVSta: Migration-
Initial VFs: 64, Total VFs: 64, Number of VFs: 0, Function Dependency Link: 01
VF offset: 128, stride: 2, Device ID: 10ed
Supported Page Size: 00000553, System Page Size: 00000001
Region 0: Memory at 00000000d0280000 (64-bit, prefetchable)
Region 3: Memory at 00000000d0380000 (64-bit, prefetchable)
VF Migration: offset: 00000000, BIR: 0
Kernel driver in use: ixgbe
Kernel modules: ixgbe
Daniel_D_Intel1
Hello FYama, Thank you for posting in Intel Ethernet Communities. Please provide the markings from the product label so we can identify the adapter. What are you using to measure throughput, and would you be able to get an iperf output using the connections on the servers? Please also provide "ethtool -i <interface>" and "ethtool -k <interface>". Let us know if you have any other questions. Best regards, Daniel D Intel Customer Support Under Contract to Intel Corporation
fYama
Hi
iperf does not show any problem, but I don't think bandwidth is the problem. but packet per second.
Ou solution sends about 250k pps ( very small packets ) to about 5000k users ( per network card )
there is a shared irq or something at hardware level that prevent-us to use both ports of the card?
( if we use 2 cards, and use 1 port of each card, we don't get this problem )
here is the info
ethtool -i enp67s0f1
driver: i40e
version: 2.7.29
firmware-version: 5.40 0x80002d35 18.0.17
expansion-rom-version:
bus-info: 0000:43:00.1
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
ethtool -k enp67s0f1
Features for enp67s0f1:
rx-checksumming: on
tx-checksumming: on
tx-checksum-ipv4: on
tx-checksum-ip-generic: off [fixed]
tx-checksum-ipv6: on
tx-checksum-fcoe-crc: off [fixed]
tx-checksum-sctp: on
scatter-gather: on
tx-scatter-gather: on
tx-scatter-gather-fraglist: off [fixed]
tcp-segmentation-offload: on
tx-tcp-segmentation: on
tx-tcp-ecn-segmentation: on
tx-tcp-mangleid-segmentation: off
tx-tcp6-segmentation: on
udp-fragmentation-offload: off
generic-segmentation-offload: on
generic-receive-offload: on
large-receive-offload: off [fixed]
rx-vlan-offload: on
tx-vlan-offload: on
ntuple-filters: on
receive-hashing: on
highdma: on
rx-vlan-filter: on [fixed]
vlan-challenged: off [fixed]
tx-lockless: off [fixed]
netns-local: off [fixed]
tx-gso-robust: off [fixed]
tx-fcoe-segmentation: off [fixed]
tx-gre-segmentation: on
tx-gre-csum-segmentation: on
tx-ipxip4-segmentation: on
tx-ipxip6-segmentation: on
tx-udp_tnl-segmentation: on
tx-udp_tnl-csum-segmentation: on
tx-gso-partial: on
tx-sctp-segmentation: off [fixed]
tx-esp-segmentation: off [fixed]
fcoe-mtu: off [fixed]
tx-nocache-copy: off
loopback: off [fixed]
rx-fcs: off [fixed]
rx-all: off [fixed]
tx-vlan-stag-hw-insert: off [fixed]
rx-vlan-stag-hw-parse: off [fixed]
rx-vlan-stag-filter: off [fixed]
l2-fwd-offload: off [fixed]
hw-tc-offload: on
esp-hw-offload: off [fixed]
esp-tx-csum-hw-offload: off [fixed]
rx-udp_tunnel-port-offload: on
Daniel_D_Intel1
Hello FYama, Thank you for the outputs. This does not seem to be an Intel retail adapter from the firmware in ethtool. Please check with the OEM of the adapter. They should be able to inform you if the adapter requires more than x8 PCIe. The 82599ES Ethernet controller requires 5.0GT/s, but the specific hardware may require more lanes. You may also check if there is a recommended firmware update for this adapter. The Intel NVM update will only work on Intel retail X710 adapters. Let us know if you have any other questions after contacting the OEM. Best regards, Daniel D Intel Customer Support Under Contract to Intel Corporation
Daniel_D_Intel1
Hello FYama, Please let us know if a firmware update from the OEM resolved this issue. If you have any other questions please do not hesitate to ask. Best regards, Daniel D Intel Customer Support Under Contract to Intel Corporation
VincentT_Intel
Hi FYama, Please let us know if there's other assistance needed. Best Regards, Vince T. Intel Customer Support Under Contract to Intel Corporation
