Ethernet Products
5779 Discussions
Using EepromAccessTool flash firmware to I210it external eeprom failed.
yanhy
We designed to use PCIe to connect i210 on NVIDIA Jetson Orin nano platform. After the device was powered on, I found that there was no program for i210, so I needed to flash once. flash using EepromAccessTool failed.
Below is the equipment information and operation steps:
root@nvidia-desktop:/home/nvidia/code/eepromaccesstool-0-8-0# lspci
0004:00:00.0 PCI bridge: NVIDIA Corporation Device 229c (rev a1)
0004:01:00.0 Non-Volatile memory controller: Phison Electronics Corporation Device 5013 (rev 01)
0008:00:00.0 PCI bridge: NVIDIA Corporation Device 229c (rev a1)
0008:01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
0009:00:00.0 PCI bridge: NVIDIA Corporation Device 229c (rev a1)
0009:01:00.0 Ethernet controller: Intel Corporation I210 Gigabit Unprogrammed (rev 03)
root@nvidia-desktop:/home/nvidia/code/eepromaccesstool-0-8-0# ./EepromAccessTool
Intel(R) EEPROM Access Tool NVM/OTP Programming Example Tool   Version 0.8.0
Provided under the terms of a CNDA.  Do Not Distribute.
Copyright(C) 2017-2019 by Intel(R) Corporation
NIC	BUS	DEV	FUN	Silicon		Memory Type Present
Check Command open to write error
 1	1	 0	 0	I210-1531	 INVM+FLASH
EepromAccessTool                              HelperFunctions.c  hex_files                          include  main.o    PciEeprom.c  testfuncs.c
EepromAccessTool_Guide_Rev1.1_2018-03-02.pdf  HelperFunctions.o  I210_Invm_SerDesKX_NoAPM_v0.6.HEX  main.c   Makefile  PciEeprom.o  testfuncs.o
root@nvidia-desktop:/home/nvidia/code/eepromaccesstool-0-8-0# ./EepromAccessTool -nic=1 -f=I210_Invm_SerDesKX_NoAPM_v0.6.HEX -mac=112233445599
size is 40000
Detected FlashId: ffff
Using generic method
Erasing Full NVM...
GetHwSemaphoreI210 MaxAttempts failed
Couldn't get a semaphore for bit bang!
^C
How can I correctly flash and set the MAC address?
Sazirah
Hi yanhy,
Since you are seeking information about on how to flash correctly and set the MAC address, please be inform that we have our dedicated Intel Embedded team experts in this issue. To get their assistance, you may post the question in Intel Embedded Forum (https://community.intel.com/t5/Embedded-Connectivity/bd-p/embedded-networking-connectivity)
They will assist you further regarding this issue.
Since we unable to provide any assistance regarding this case and you will posting in Intel Embedded Forum, we will proceed with closing this case at our end.
Thank you for using Intel products and services.
Sazzy_Intel
CarlosAM_INTEL
Hello, @Sazirah:
We need to clarify that this forum is not related to an Intel Embedded Platform (it is related to an NVIDIA Jetson Orin nano platform) and it is related to the Intel® Ethernet Controller I210.
Due to this, the customer request is out of our scope of support.
Please consider this information when you provide the previous suggestion, or transfer any forums to the channel that you mentioned in your previous communication.
@CarlosAM_INTEL.
