It takes us more than one week to fix this problem, but failed. Our server is built as belows
Motherboard: Intel S2600CW2R
CPU: E5 2660 V4
Network Adapter: XL710-QDA2
OS: Linux Ubuntu 16.04
We are using Intel QSFP Configuration Utility to config ports as 4x10G mode. All NVMs and drivers have been updated to the latest version. Here are the details of our log file. Anybody could give us some help? Thanks in advance.
tb-user@tbuser-S2600CWR:~/LinuxTool/Linux_x64$ sudo ./qcu64e /DEVICES
[sudo] password for tb-user:
Intel(R) QSFP+ Configuration Utility
QCU version: v2.27.10.01
Copyright(C) 2016 by Intel Corporation.
Software released under Intel Proprietary License.
NIC Seg:Bus Ven-Dev Mode Adapter Name
1) 000:004 8086-1583 N/A Intel(R) Ethernet Converged Network Adapter XL710-
tb-user@tbuser-S2600CWR:~/LinuxTool/Linux_x64$ sudo ./qcu64e /NIC=1 /set=4x10
QSFP+ Configuration modification is not supported by this adapter.
tb-user@tbuser-S2600CWR:~/LinuxTool/Linux_x64$ ifconfig -a
enp1s0f0 Link encap:Ethernet HWaddr a4:bf:01:1b:89:9e
inet addr:150.236.28.199 Bcast:150.236.28.223 Mask:255.255.255.224
inet6 addr: fe80::5622:3a76:5c53:30f4/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:4079 errors:0 dropped:0 overruns:0 frame:0
TX packets:322 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:472072 (472.0 KB) TX bytes:38743 (38.7 KB)
Memory:91920000-9193ffff
enp1s0f1 Link encap:Ethernet HWaddr a4:bf:01:1b:89:9f
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Memory:91900000-9191ffff
ens261f0 Link encap:Ethernet HWaddr 00:16:f6:f6:10:0a
ens261f1 Link encap:Ethernet HWaddr 00:16:f6:f6:10:0b
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:138 errors:0 dropped:0 overruns:0 frame:0
TX packets:138 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:12084 (12.0 KB) TX bytes:12084 (12.0 KB)
tb-user@tbuser-S2600CWR:~/LinuxTool/Linux_x64$ sudo ethtool ens3f2
Settings for ens3f2:
Hi Chinabanker,
Thank you for posting in Wired Communities. Can you share what is the SFP+ module brand and model used for the XL710-QDA2?
Sharon T
Hi, Sharon
Thank you for the response first. We were using Dell's XL710-QDA2 and their QSFP+ modules. Today we replace them with Intel branded XL710. It's now all right to use Intel QCU to configure all the modes of ports.
Obviously, Intel QCU ONLY supports to Intel branded NIC. Although other OEM XL710 adapters are using same Intel XL710 chips, they are not working with Intel utilities. Ridiculous!
I wish this case could help others who suffer same problems as us.
Hi Chinabanker,
Thank you for the update and sharing the information. I am glad using the Intel XL710 works for you now. Apologize for any inconvenience and thanks again for the useful information.
Sharon T
