My server is running RedHat 7.1.
ixgbe - 4.0.1-k-rh7.1
ixgbevf: 2.12.1-k
igb:5.2.13-k
igbvf: 2.0.2-k
I want to assign the fix MAC to VF, so I configure like this
# cat /etc/rc.d/rc.local
echo 1 > /sys/class/net/bi0/device/sriov_numvfs
ip link set bi0 vf 0 mac 00:6f:2a:01:b0:00
echo 1 > /sys/class/net/fi0/device/sriov_numvfs
ip link set fi0 vf 0 mac 00:6f:2a:01:f0:00
While after system reboot, the MAC of VF fi0 is not expected. (The VFs are loaded in Host OS.)
# ip link show
1: lo: mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: fi0: mtu 1500 qdisc mq state UP mode DEFAULT qlen 1000
link/ether 00:a0:a5:68:b9:24 brd ff:ff:ff:ff:ff:ff
vf 0 MAC 00:6f:2a:01:f0:00, spoof checking on, link-state auto
3: fi1: mtu 1500 qdisc mq state DOWN mode DEFAULT qlen 1000
link/ether 00:a0:a5:68:b9:25 brd ff:ff:ff:ff:ff:ff
vf 0 MAC 00:6f:2a:01:f1:00, spoof checking on, link-state auto
4: mgmt0: mtu 1500 qdisc mq state DOWN mode DEFAULT qlen 1000
link/ether 00:a0:a5:68:b9:22 brd ff:ff:ff:ff:ff:ff
5: mgmt1: mtu 1500 qdisc mq state DOWN mode DEFAULT qlen 1000
link/ether 00:a0:a5:68:b9:23 brd ff:ff:ff:ff:ff:ff
6: bi0: mtu 1500 qdisc mq state UP mode DEFAULT qlen 1000
link/ether 00:a0:a5:68:b9:20 brd ff:ff:ff:ff:ff:ff
vf 0 MAC 00:6f:2a:01:b0:00, spoof checking on, link-state auto
7: bi1: mtu 1500 qdisc mq state DOWN mode DEFAULT qlen 1000
link/ether 00:a0:a5:68:b9:21 brd ff:ff:ff:ff:ff:ff
vf 0 MAC 00:6f:2a:01:b1:00, spoof checking on, link-state auto
8: bi0_vf0: mtu 1500 qdisc pfifo_fast state UP mode DEFAULT qlen 1000
link/ether 00:6f:2a:01:b0:00 brd ff:ff:ff:ff:ff:ff
9: bi1_vf1: mtu 1500 qdisc pfifo_fast state DOWN mode DEFAULT qlen 1000
link/ether 86:56:ec:3e:7f:8f brd ff:ff:ff:ff:ff:ff
10: fi0_vf0: mtu 1500 qdisc mq state UP mode DEFAULT qlen 1000
link/ether f2:35:76:f5:02:82 brd ff:ff:ff:ff:ff:ff
11: virbr0: mtu 1500 qdisc noqueue state DOWN mode DEFAULT
link/ether 52:54:00:45:b8:12 brd ff:ff:ff:ff:ff:ff
12: fi1_vf0: mtu 1500 qdisc mq state DOWN mode DEFAULT qlen 1000
link/ether 2a:9a:2e:0b:45:88 brd ff:ff:ff:ff:ff:ff
13: virbr0-nic: mtu 1500 qdisc pfifo_fast master virbr0 state DOWN mode DEFAULT qlen 500
Do you have any idea?
Br, Nicole
The adapters are:
bi0 - Ethernet controller: Intel Corporation 82576 Gigabit Network Connection (rev 01)
fi0 - Ethernet controller: Intel Corporation 82599EB 10-Gigabit KX4 Network Connection (rev 01)
Br, Nicole
Hi Nicole,
Thank you for the post. I will check on this.
rgds
wb
Hi Nicole.Z,
Please provide Linux Host kernel log and VM (Guest) Linux kernel Log. The Linux kernel log can be found at /var/log/messages.
wb
Hi Nicole.Z
Thank you for the info. We will check on this.
rgds,
wb
Hi Nicole.Z
Further checking ,the adminstrator set VF MAC address then later on Network Manager tried to set VF MAC address that was disallowed then VF has to be reset. Since Intel PF and VF drivers has a built in security feature called administrative assignment of VF MAC address. If the server administrator assigns a VF MAC address from the HOST any subsequent changes to the VF MAC address are disallowed.
Thus please try disabling the network manager.
rgds,
wb
I tried to disable NetworkManager, but after reboot the VFs never boot up, and MAC are still unexpected. Tried to restart network service, it didn't help.
# systemctl status NetworkManager ! !
NetworkManager.service - Network Manager
Loaded: loaded (/usr/lib/systemd/system/NetworkManager.service; disabled)
Active: inactive (dead)
# ip link show
4: mgmt0: mtu 1500 qdisc noop state DOWN mode DEFAULT qlen 1000
5: mgmt1: mtu 1500 qdisc noop state DOWN mode DEFAULT qlen 1000
7: bi1: mtu 1500 qdisc noop state DOWN mode DEFAULT qlen 1000
8: bi0_vf0: mtu 1500 qdisc noop state DOWN mode DEFAULT qlen 1000
link/ether 22:e3:dc:63:90:6e brd ff:ff:ff:ff:ff:ff
9: fi0_vf0: mtu 1500 qdisc noop state DOWN mode DEFAULT qlen 1000
link/ether 00:6f:2a:01:f0:00 brd ff:ff:ff:ff:ff:ff
10: virbr0: mtu 1500 qdisc noqueue state DOWN mode DEFAULT
11: virbr0-nic: mtu 1500 qdisc pfifo_fast master virbr0 state DOWN mode DEFAULT qlen 500
Br, Nicole
Hi NicoleZ,
Thank you for the update. I will further check on this.
rgds,
wb
HI Nicole.Z
You may upgrade to newer VF driver version at https://downloadcenter.intel.com/product/32609/Intel-82599-10-Gigabit-Ethernet-Controller https://downloadcenter.intel.com/product/32609/Intel-82599-10-Gigabit-Ethernet-Controller. Please contact your system vendor if you using using an onboard NIC for them to further assist on this.
rgds,
wb
