Ethernet Products
5528 Discussions
VF bus-info is null with xen4.4
DKang4
Hi guys!
I installed Ubuntu 12.04 LTS(Kernel version: 3.8.1) and Xen 4.4 to make VM using VF.
I use 2 82599 10G nic.
So I made some VFs and set "iommu=1" in GRUB like these.
root@NewXebra2:/guest# lspci | grep Eth
01:00.0 Ethernet controller: Intel Corporation 82576 Gigabit Network Connection (rev 01)
01:00.1 Ethernet controller: Intel Corporation 82576 Gigabit Network Connection (rev 01)
82:00.0 Ethernet controller: Intel Corporation 82599EB 10-Gigabit SFI/SFP+ Network Connection (rev 01)
82:00.1 Ethernet controller: Intel Corporation 82599EB 10-Gigabit SFI/SFP+ Network Connection (rev 01)
82:10.0 Ethernet controller: Intel Corporation 82599 Ethernet Controller Virtual Function (rev 01)
82:10.1 Ethernet controller: Intel Corporation 82599 Ethernet Controller Virtual Function (rev 01)
82:10.2 Ethernet controller: Intel Corporation 82599 Ethernet Controller Virtual Function (rev 01)
82:10.3 Ethernet controller: Intel Corporation 82599 Ethernet Controller Virtual Function (rev 01)
82:10.4 Ethernet controller: Intel Corporation 82599 Ethernet Controller Virtual Function (rev 01)
82:10.5 Ethernet controller: Intel Corporation 82599 Ethernet Controller Virtual Function (rev 01)
82:10.6 Ethernet controller: Intel Corporation 82599 Ethernet Controller Virtual Function (rev 01)
82:10.7 Ethernet controller: Intel Corporation 82599 Ethernet Controller Virtual Function (rev 01)
84:00.0 Ethernet controller: Intel Corporation 82599EB 10-Gigabit SFI/SFP+ Network Connection (rev 01)
84:00.1 Ethernet controller: Intel Corporation 82599EB 10-Gigabit SFI/SFP+ Network Connection (rev 01)
84:10.0 Ethernet controller: Intel Corporation 82599 Ethernet Controller Virtual Function (rev 01)
84:10.1 Ethernet controller: Intel Corporation 82599 Ethernet Controller Virtual Function (rev 01)
84:10.2 Ethernet controller: Intel Corporation 82599 Ethernet Controller Virtual Function (rev 01)
84:10.3 Ethernet controller: Intel Corporation 82599 Ethernet Controller Virtual Function (rev 01)
84:10.4 Ethernet controller: Intel Corporation 82599 Ethernet Controller Virtual Function (rev 01)
84:10.5 Ethernet controller: Intel Corporation 82599 Ethernet Controller Virtual Function (rev 01)
84:10.6 Ethernet controller: Intel Corporation 82599 Ethernet Controller Virtual Function (rev 01)
84:10.7 Ethernet controller: Intel Corporation 82599 Ethernet Controller Virtual Function (rev 01)
And I also made VM(Paravirtualized Ubuntu 10.04 LTS) with 2 VFs. But...
it doesn't work...
Below, there are some information of Eth0(VF) by ethtool.
driver: ixgbevf
version: 2.11.3
firmware-version: N/A
bus-info: 0000:00:00.0
As you can see, bus address is null.
I also checked xen & ubuntu dmesg, but I can't find problem.
This is xen dmesg.
(XEN) Processor # 34 6:12 APIC version 21
(XEN) ACPI: LAPIC (acpi_id[0x09] lapic_id[0x24] enabled)
(XEN) Processor # 36 6:12 APIC version 21
(XEN) ACPI: LAPIC (acpi_id[0x0a] lapic_id[0x30] enabled)
(XEN) Processor # 48 6:12 APIC version 21
(XEN) ACPI: LAPIC (acpi_id[0x0b] lapic_id[0x32] enabled)
(XEN) Processor # 50 6:12 APIC version 21
(XEN) ACPI: LAPIC (acpi_id[0x0c] lapic_id[0x34] enabled)
(XEN) Processor # 52 6:12 APIC version 21
(XEN) ACPI: LAPIC (acpi_id[0x0d] lapic_id[0x01] enabled)
(XEN) Processor # 1 6:12 APIC version 21
(XEN) ACPI: LAPIC (acpi_id[0x0e] lapic_id[0x03] enabled)
(XEN) Processor # 3 6:12 APIC version 21
(XEN) ACPI: LAPIC (acpi_id[0x0f] lapic_id[0x05] enabled)
(XEN) Processor # 5 6:12 APIC version 21
(XEN) ACPI: LAPIC (acpi_id[0x10] lapic_id[0x11] enabled)
(XEN) Processor # 17 6:12 APIC version 21
(XEN) ACPI: LAPIC (acpi_id[0x11] lapic_id[0x13] enabled)
(XEN) Processor # 19 6:12 APIC version 21
(XEN) ACPI: LAPIC (acpi_id[0x12] lapic_id[0x15] enabled)
(XEN) Processor # 21 6:12 APIC version 21
(XEN) ACPI: LAPIC (acpi_id[0x13] lapic_id[0x21] enabled)
(XEN) Processor # 33 6:12 APIC version 21
(XEN) ACPI: LAPIC (acpi_id[0x14] lapic_id[0x23] enabled)
(XEN) Processor # 35 6:12 APIC version 21
(XEN) ACPI: LAPIC (acpi_id[0x15] lapic_id[0x25] enabled)
(XEN) Processor # 37 6:12 APIC version 21
(XEN) ACPI: LAPIC (acpi_id[0x16] lapic_id[0x31] enabled)
(XEN) Processor # 49 6:12 APIC version 21
(XEN) ACPI: LAPIC (acpi_id[0x17] lapic_id[0x33] enabled)
(XEN) Processor # 51 6:12 APIC version 21
(XEN) ACPI: LAPIC (acpi_id[0x18] lapic_id[0x35] enabled)
(XEN) Processor # 53 6:12 APIC version 21
(XEN) ACPI: LAPIC_NMI (acpi_id[0xff] dfl dfl lint[0x1])
(XEN) Overriding APIC driver with bigsmp
(XEN) ACPI: IOAPIC (id[0x06] address[0xfec00000] gsi_base[0])
(XEN) IOAPIC[0]: apic_id 6, version 32, address 0xfec00000, GSI 0-23
(XEN) ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
(XEN) ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
(XEN) ACPI: IRQ0 used by override.
(XEN) ACPI: IRQ2 used by override.
(XEN) ACPI: IRQ9 used by override.
(XEN) Enabling APIC mode: Phys. Using 1 I/O APICs
(XEN) ACPI: HPET id: 0x8086a301 base: 0xfed00000
(XEN) Failed to get Error Log Address Range.
(XEN) Using ACPI (MADT) for SMP configuration information
(XEN) SMP: Allowing 24 CPUs (0 hotpl...
