Ethernet Products
4874 Discussions
VF creation failure - x710 Intel adapter
RKazh
HI,
I am trying new Intel controller with sr-iov functions , and there are 2 problems with VF creation once the SFPs are connected to the swich and the link is UP.
  1. During server boot there is strange message ": Non-contiguous TC "
  2. If I am truing to create VF after OS is loaded :
if the link is up - VF failed .
if the link is down VF created , but cannot get line rate .
If the server loaded without link UP - everything works perfectly.
log example :
Feb 12 17:28:22 FORTIpoc1 kernel: i40e 0000:05:00.0: couldn't add VEB, err I40E_ERR_ADMIN_QUEUE_ERROR aq_err I40E_AQ_RC_ENXIO
Feb 12 17:28:22 FORTIpoc1 kernel: i40e 0000:05:00.0: add vsi failed for VF 0, aq_err 6
the " Non-contiguous TC " message during the bootloader , long before kernel .
Same issue i have on two differen HP servers G10 and G9
also Redhat 7 and Centos7.7 OS
Info :
# dmidecode 3.2
Getting SMBIOS data from sysfs.
SMBIOS 3.2.1 present.
# SMBIOS implementations newer than version 3.2.0 are not
# fully supported by this version of dmidecode.
Handle 0x0091, DMI type 3, 21 bytes
Chassis Information
    Manufacturer: HPE
    Type: Rack Mount Chassis
    Lock: Not Present
    Version: Not Specified
    Serial Number: CZJ93802PS
    Asset Tag:
    Boot-up State: Safe
    Power Supply State: Safe
    Thermal State: Safe
    Security Status: Unknown
    OEM Information: 0x00000000
    Height: 1 U
    Number Of Power Cords: 2
    Contained Elements: 0
11:00.0 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 02)
11:00.1 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 02)
11:02.0 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
11:0a.0 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
[root@fkvm ~]# ethtool -i ens1f0
driver: i40e
version: 2.10.19.82
firmware-version: 7.20 0x8000794b 1.2585.0
expansion-rom-version:
bus-info: 0000:11:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
Thank you
Ruslan
Caguicla_Intel
Hello Ruslan,
We'd like to check if you have tried the steps from the link below?
SR-IOV Configuration Guide Intel® Ethernet CNA X710 & XL710 on Red Hat* Enterprise Linux 7*
https://www.intel.com/content/dam/www/public/us/en/documents/technology-briefs/xl710-sr-iov-config-guide-gbe-linux-brief.pdf
Please also share the links where the driver and firmware were downloaded form.
We look forward to your response.
In case we don't hear form you, we will follow up after 3 business days.
Crisselle C
Intel® Customer Support
RKazh
Hi Crisselle . For VF creation we are using the same guide you sent. Driver and firmware were downloaded from Intel site also https://downloadcenter.intel.com/download/24411/Intel-Network-Adapter-Driver-for-PCIe-40-Gigabit-Ethernet-Network-Connections-Under-Linux-?product=24586 Thank you ! Regards, Ruslan Kazhdan Network Engeneer Wired Communication Department [cid:image001.png@01D0F3C9.D3682BE0]
Caguicla_Intel
Hello Ruslan,
Appreciate your response.
Please allow us to check on your query. We will give you an update as soon as possible but no later than 3 business days.
Hoping for your kind patience.
Crisselle C
Caguicla_Intel
Hello Ruslan,
Good day!
While we are checking on this, can you share if you have already tried the latest VF driver from the link below?
https://downloadcenter.intel.com/download/24693/Intel-Network-Adapter-Virtual-Function-Driver-for-Intel-Ethernet-Controller-700-Series?product=82947
You also mentioned that you have different HP servers G10 and G9 having the same issue, kindly provide the model of the Ethernet adapters installed on your server as well as the Physical Function (PF) and Virtual Function (VF) loaded.
In case we don't receive a reply, we will follow up after 3 business days.
Crisselle C
RKazh
Hi, The iavf drivers is also updated to last version. ( one you sent ) Regarding different servers , I used same card model x710-da2 in hpg9 and hp g10 also , and exchange between them – same results. I suspecting that the issue is related to DCB features I took it from the error output during the boot process and from your README file Data Center Bridging (DCB)
Caguicla_Intel
Hello Ruslan,
Thank you for the reply.
We will continue to check on this issue. We will give you an update once there is any findings but no later than 3 business days.
Hoping for your king understanding.
Crisselle C
Caguicla_Intel
Hello Ruslan,
Good day!
While we are checking on this, you've mentioned that you suspected that the issue is related to DCB features. With this, we'd like to confirm if you have enabled the DCB feature? If yes, have you tried disabling it to check if the issue would still persist?
Awaiting to hear from you.
Should there be no response, we will follow up after 3 business days.
Crisselle C
Caguicla_Intel
Hello Ruslan,
How are you today?
We'd like to check if you have read our previous message. If you do, please share the requested additional details for us to further investigate the issue.
We will follow up after 3 business days in case we don't hear from you.
Crisselle C
RKazh
Hi, Those switches are not supporting any DCB features , on intel side I don’t know how to disable it. I addition , the cisco 9300 is not causing any problem during the server boot process ( mistake in the previous mail ) – only Juniper 4500 for now causing the problem . Thank you Regards, Ruslan Kazhdan Network Engeneer Wired Communication Department [cid:image001.png@01D0F3C9.D3682BE0]
Caguicla_Intel
Hello Ruslan,
Can you share the exact error message you got when using the  Juniper 4500? This would help us in further investigating the issue.
Just to clarify, if you tried to connect any of your servers to Cisco 9300, you don't encounter any issues on VF creation or SR-IOV functions and the problem is only specific to Juniper 4500? Kindly confirm.
Crisselle C
RKazh
Hi Right after the boot loader the error is Non-contiguous TC …. ( unfortunately I cannot reproduce this error again to have an exact message ) And in Linux log is ( dmesg) Feb 12 17:28:22 FORTIpoc1 kernel: i40e 0000:05:00.0: couldn't add VEB, err I40E_ERR_ADMIN_QUEUE_ERROR aq_err I40E_AQ_RC_ENXIO Feb 12 17:28:22 FORTIpoc1 kernel: i40e 0000:05:00.0: couldn't add VEB Feb 12 17:28:22 FORTIpoc1 kernel: i40e 0000:05:00.0: add vsi failed for VF 0, aq_err 6 Both of the logs are even befoure the VF creation. If the servers are connected to cisco 9300 I don’t encounter any issues on VF creation or SR-IOV functions. For now the problem the is only specific to Juniper 4500 Regards, Ruslan Kazhdan Network Engeneer Wired Communication Department [cid:image001.png@01D0F3C9.D3682BE0]
Caguicla_Intel
Hello Ruslan,
Good day!
We'd like to follow up the additional information we requested as this would help us in further checking your query.
Crisselle C
Caguicla_Intel
Hello Ruslan,
Please allow us to continue to check on this. We will give you an update as soon as there is any findings but no later than 3 business days.
Hoping for your patience.
Crisselle C
Caguicla_Intel
Hello Ruslan,
Good day!
We sincerely apologize for the delay on this matter as we are thoroughly checking on this. Please give us more time to look into this. Rest assured that we will give you an update as soon as there is any findings but not later than 3 business days.
Thank you for your kind understanding.
Crisselle C
Caguicla_Intel
Hello Ruslan,
Good day!
While we are still investigating on this, we'd like to check if you have tried the latest PF – 2.11.29 from sourceforge link below. https://sourceforge.net/projects/e1000/files/i40e%20stable/
Crisselle C
Caguicla_Intel
Hello Ruslan,
How are you today?
Please let us know if you have already tried the driver from the link above and share the results with us.
We will follow up after 3 business days in case we don't receive a reply.
Crisselle C
RKazh
Hi, Those servers are in production environment , I have to wait for a new srv to install and check the drivers. It will take some time. Regards, Ruslan Kazhdan Network Engeneer Wired Communication Department [cid:image001.png@01D0F3C9.D3682BE0]
Caguicla_Intel
Hello Ruslan,
We understand the the server is already in production. With this, we'd like to check if it is alright to temporarily close this request or would you prefer to keep this open. If the latter, please let us know on when do you expect to to test the latest PF driver from the above link.
We hope to hear from you soon.
Crisselle C
Caguicla_Intel
Hello Ruslan,
Good day!
We'd like to check if you have read our previous message. If you do, please share if you want to temporarily close this request or would you prefer to keep this open. If the latter, please let us know on when do you expect to to test the latest PF driver from the above link.
Crisselle C
Caguicla_Intel
Hello Ruslan,
How are you today?
Please be informed that we will now close this request since we haven't received any response from our previous follow ups. Just feel free to post a new question if you may have any other inquiry in the future.
May you have an amazing day ahead!
Crisselle C
