Ethernet Products
4935 Discussions
VF failed to receive vlan tagged packet sent by another VF connected directly without switch
darkless
Everything is ok if vlan is not set. That is to say, packets are sent by ens1f0 vf0 and packets are received successfully by ens1f1 vf0. The ens1f0 and ens1f1 is connected directly with physical cable.
But ens1f1 vf0 can't receive anything if vlan is set in both sides. DPDK is used to send and receive/capture packet.
Is it that I forget some important setting for PF here? Looking forward to your good suggestion what to check.
#how I set vlan ID
ip link set ens1f0 vf 0 mac 00:11:22:33:44:66 vlan 2
ip link set ens1f1 vf 0 mac 00:11:22:33:44:55 vlan 2
#How NIC VF is controlled by DPDK
Network devices using DPDK-compatible driver
0000:03:10.0 '82599 Ethernet Controller Virtual Function 10ed' drv=igb_uio unused=ixgbevf
0000:03:10.1 '82599 Ethernet Controller Virtual Function 10ed' drv=igb_uio unused=ixgbevf
#how to look like when I input "ip link show"
4: ens1f0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 9600 qdisc mq state UP mode DEFAULT group default qlen 1000
link/ether f8:f2:1e:13:e0:9c brd ff:ff:ff:ff:ff:ff
vf 0 MAC 00:11:22:33:44:66, vlan 2, spoof checking off, link-state auto, trust on, query_rss off
5: ens1f1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 9600 qdisc mq state UP mode DEFAULT group default qlen 1000
link/ether f8:f2:1e:13:e0:9d brd ff:ff:ff:ff:ff:ff
vf 0 MAC 00:11:22:33:44:55, vlan 2, spoof checking off, link-state auto, trust on, query_rss off
Mike_Intel
Hello darkless,
Since this question involves DPDK, please check with Intel Premier Support for further assistance. See the following for access to Intel Premier Support.
Click the "Access and Log In" to contact the DPDK support https://www.intel.com/content/www/us/en/design/support/ips/training/welcome.html
Please be informed that we will now close this request. Just feel free to post a new question if you may have any other inquiry in the future as this thread will no longer be monitored.
May you have a great day!
Thank you.
Michael L.
