Ethernet Products
5721 Discussions
VLAN Virtual Adapters - Windows 10 1903 - Disappeared
IDepa11
We utilise virtual VLAN adapters to connect to different VLANs - and create these using powershell. We have a problem whereby these Virtual Adaptors seem to vanish after reboots.
The only way to get them back is to remove them using powershell (which also seems to error but then lets you re-implement them again).
OS - Windows 10 x64 1903 - Fully up to date
Drivers - Intel 24.2 NIC drivers - Latest available.
Does anyone else experience this issue or know how to resolve this permanently?
Thanks!
commands used below :-
PS C:\WINDOWS\system32> Remove-IntelNetVLAN
cmdlet Remove-IntelNetVLAN at command pipeline position 1
Supply values for the following parameters:
ParentName[0]: Intel(R) Ethernet Connection (2) I219-LM
ParentName[1]:
VLANID[0]: 401
VLANID[1]: 0
VLANID[2]:
Remove-IntelNetVLAN : Failed to remove one or more of the specified VLAN IDs.
At line:1 char:1
+ Remove-IntelNetVLAN
  + CategoryInfo     : InvalidOperation: (:) [Remove-IntelNetVLAN], Exception
  + FullyQualifiedErrorId : Error executing cmdlet.,Intel.PowerShell.Network.VLAN.RemoveIntelNetVlan
PS C:\WINDOWS\system32> Add-IntelNetVLAN -ParentName "Intel(R) Ethernet Connection (2) I219-LM" -VLANID "401,0"
Caption        : Intel(R) Ethernet Connection (2) I219-LM - VLAN : VLAN401
Description      : Intel(R) Advanced Network Services Virtual Adapter is used for advanced features like teaming and virtual LAN
InstallDate      :
Status         :
CreationClassName   : IANet_VLAN
SystemCreationClassName : Win32_ComputerSystem
SystemName       : PICO-244D
VLANNumber       : 401
DeviceStatus      : 0
DeviceStatusString   : Disabled
Parent         : Intel(R) Ethernet Connection (2) I219-LM
ParentID        : {365347C7-DA25-4B63-B0D6-766A04783884}
ParentName       : Intel(R) Ethernet Connection (2) I219-LM
ParentType       : 0
StatusInfo       : 4
VLANID         : 401
VLANName        : VLAN401
PSComputerName     :
Caption        : Intel(R) Ethernet Connection (2) I219-LM - VLAN : Untagged
InstallDate      :
Status         :
VLANNumber       : 0
DeviceStatus      : 0
ParentType       : 0
StatusInfo       : 4
VLANID         : 0
VLANName        : Untagged
PSComputerName     :
Caguicla_Intel
Hello IDepa11,
Thank you for posting in Intel Ethernet Communities. Kindly provide the following details for us to check on your query.
1.) System Support Utility log of your system. This will allow us to check your Adapter details and configuration. Kindly refer to the steps below.
a- https://downloadcenter.intel.com/product/91600/Intel-System-Support-Utility
b- Open SSU.exe
c- Mark the box "Everything" and then click "Scan".
d- When finished scanning, click "Next".
e- Click on "Save" and attach the file to a post.
2.) Is this a newly updated OS? If yes, does the issue only appear after the update?
3.) Have you tried the driver provided by the board vendor?
4.) Please share the return value for Get-IntelNetVLAN.
You may refer to this link for the Intel® PROSet for Windows PowerShell* Software
https://www.intel.com/content/www/us/en/support/articles/000023545/network-and-io.html
5.) Please also share how may units are having this issue.
Crisselle C
Intel Customer Support
A Contingent Worker at Intel
Caguicla_Intel
Hello IDepa11,
Good day!
Please provide the requested information for us to check on your query. In case you have additional questions on this matter, please let us know.
Awaiting to your reply.
Crisselle C
Caguicla_Intel
Hello IDepa11,
How are you today?
Please be informed that we will now proceed closing this request since we haven't received any response from our previous follow up. Should you have any other concern or assistance needed in the future, please do no hesitate to post a new question.
Crisselle C
