Ethernet Products
5821 Discussions
W11 1.0 Gbps/Full Duplex doesn't work on Intel(R) Ethernet Connection (7) I219-V
chay
My ethernet Connection Speed is limited to 100/100 (Mbps) and I can't change it by enabling the 1.0 Gbps/Full Duplex on Speed & Duplex value configuration. When I set this value, the ethernet stops. I use cabbled ethernet.
My driver version (12.19.0.16) is the lastest and I use Windows 11.
My brother have also a PC, we use the same router and his configuration is 1000/1000 (Mbps), his Speed & Duplex value being 1.0 Gbps/Full Duplex. Also, his pc has an different driver, a realtek driver. Meaning that my problem is in the driver, not in the router or cable.
Resuming, my main problem is: My ethernet is limited to 100/100 Mbps (Auto Negotiation value) and I can't increase it. The speed & duplex gigabit value (1.0 Gbps/Full Duplex) doesn't work in my driver.
chay
my problem was the cable
chay
I forgot to mention, but my the provider provides 150 Mbps.
chay
