Ethernet Products
Wake On Lan
MChen66
Hi, Is the intel lan chip I217 can support Wake On Lan after remove AC -> plug AC
If yes, how to use it?
If not, why? Any limitations?
VincentT_T_Intel
Hi Mantou, based on the datasheet it supports wake on LAN on all power state, AC should be plug in with system on shutdown or standby state, then initiate a wake up from remote using magic packet.
data sheet:
http://www.intel.ph/content/dam/www/public/us/en/documents/datasheets/i217-ethernet-controller-datasheet.pdf http://www.intel.ph/content/dam/www/public/us/en/documents/datasheets/i217-ethernet-controller-datasheet.pdf
hope this helps.
