Ethernet Products
4877 Discussions
What is the operating temperature for the QSFP+ and QSFP+ breakout cables?
ChunHuat_Y_Intel
(XLDACBLxand X4DACBLx, wherex= 1,3 or 5)
Hi gar\yeohchux,
Thank you for contacting Intel.
The operating temperature of Intel® Ethernet QSFP+ Optics is 0 to 70°C. However, there's no operating temperature for cable since it doesn't have operating components in it.
Please refer to Product Briefs on the links below:
1. http://www.intel.ph/content/dam/www/public/us/en/documents/product-briefs/ethernet-qsfp-optics-brief.pdf Intel® Ethernet QSFP+ Optics
2. http://www.intel.com/content/dam/www/public/us/en/documents/product-briefs/ethernet-qsfp-cables-brief.pdf Intel® Ethernet QSFP+ Cables
Please let us know if you have other inquiries.
Sincerely,
Sandy
ChunHuat_Y_Intel
Hi Sandy,
Do you know why there is no stated operating temperature for Intel Ethernet QSFP+ breakout cable under Product briefs?
http://www.intel.com/content/www/us/en/ethernet-products/optics-cables/ethernet-qsfp-cables-brief.html Intel® Ethernet QSFP+ Cables Product Brief
I saw Intel Ethernet SFP+ Twinaxial Cable Product briefs listed Electrical/Cables Characteristics or Intel Ethernet QSFP+ Optic Product briefs listed Optical Characteristics SR4, why there is no listed for Intel Ethernet QSFP+ cable Product briefs?
http://www.intel.com/content/www/us/en/ethernet-products/optics-cables/ethernet-sfp-twinaxial-cables-brief.html Intel® Ethernet SFP+ Twinaxial Cables Product Brief
http://www.intel.com/content/dam/www/public/us/en/documents/product-briefs/ethernet-qsfp-optics-brief.pdf http://www.intel.com/content/dam/www/public/us/en/documents/product-briefs/ethernet-qsfp-optics-brief.pdf
Patrick
Hi Patrick,
Thanks for writing back.
The breakout cable didn't have operating temperature is because it doesn't have any components that is operating in it.
Sincerely,
Sandy
ChunHuat_Y_Intel
Hi Sandy,
Follow up questions.
So the QSFP+ twinaxial cables and breakout cables do not comply to the commercial temperature range of 0-70C and do not have operating temperatures?
If so, why is there a need for the heatsink on the QSFP+ connector on the OCP board?
Patrick
Hi Patrick,
In order to further verify your inquiry, can you please provide further information, a photo maybe. of the heat sink you are referring to. Thanks.
Sincerely,
Sandra
ChunHuat_Y_Intel
Hi Sandy,
I am attaching picture for you as reference. This is the heasink customer mention on it.
What purpose attached heatsink for the QSFP+ connector?
Patrick
Hi Patrick,
The heatsink are there to prevent the part from overheating since it is attached to the card.
Sincerely,
Sandy
ChunHuat_Y_Intel
Hi Sandy,
Is there any issue or impact if without heatsink attached above QSFP+ connector?
Patrick Yeoh
Hi Patrick,
Thank you for your reply. The connector will experience overheating without the heatsink.
Sincerely,
Sandy
ChunHuat_Y_Intel
Hi Sandy,
Customer mentioned that "The heatsink for purpose to prevent the part from overheating since it is attached to the adapter card".
So this statement is only applicable for the Intel Ethernet QSFP+ Optics since it has an operating temperature?
If we do not have the heatsink, it should not be a concern for the Intel Ethernet QSFP+ Twinaxial cable and the Intel Ethernet QSFP+ Breakout cable?
Patrick
Hi Patrick,
Yes, it should not be a concern if the twinaxial and breakout cables are going to have heatsink or not. If heatsink is needed, it would already be built-in to the connectors of these cables.
Sincerely,
Sandy
ChunHuat_Y_Intel
Hi Sandy,
Customer questions again.
The Intel Ethernet QSFP+ Optics does not have a heatsink on board even though it has an operating temperature of 0-70C. It would be using the heatsink that is on the QSFP+ connector on the Fisher Flat.
I believe there should be an operating temperature specification even for the Intel Ethernet QSFP+ Twinaxial cable and the Intel Ethernet QSFP+ Breakout cable if they are to comply to the SFF-8436 specification.
Patrick
Hi Patrick,
Regarding the operating temperature of QSFP+ Breakout cable, we will try to add it to the product brief.
Sincerely,
Sandy
