Ethernet Products
5611 Discussions
What to do for i354 link to come up? It is not coming up whereas i350 link is ok as well as i210 link is ok.
Muthurajan_J_Intel
I am observing a strange issue with i354 when auto-negotiation is turned off.
The device I have has 6 ethernet ports. Port 1 and 2 are based on i210 and port
3 to 6 are based on i354 (connected thru an external PHY). The CPU is Atom
Rangeley (4 core).
I have connected ports 3 and 4 back to back with an external cable. When the
link is forced to 100M/Full duplex with auto-negotiation off on both the ports,
the link does not come up.
Whereas the link comes up fine when eth3 (i354) and eth1 (i210) are connected
back to back and forced to 100M/Full duplex with auto-negotiation off.
This issue is seen with linux kernel (ubuntu 14.04).
Is this a known issue ?
Following are logs when running the test using ethtool from linux
admin@Ananda-Desk:~$ lspci | grep Ethernet
00:14.0 Ethernet controller: Intel Corporation Ethernet Connection I354 (rev
03) - eth2
00:14.1 Ethernet controller: Intel Corporation Ethernet Connection I354 (rev
03) - eth3
00:14.2 Ethernet controller: Intel Corporation Ethernet Connection I354 (rev
03) - eth4
00:14.3 Ethernet controller: Intel Corporation Ethernet Connection I354 (rev
03) - eth5
01:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection
(rev 03) - eth0
02:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection
(rev 03) - eth1
admin@Ananda-Desk:~$ ethtool -i eth3
driver: igb
version: 5.2.13-k
firmware-version: 0.0.0
bus-info: 0000:00:14.1
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: no
[Force 100M/Full on eth3]
admin@Ananda-Desk:~$ sudo ethtool -s eth3 autoneg off duplex full speed 100
admin@Ananda-Desk:~$ ethtool eth3
Settings for eth3:
Supported ports: [ TP ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
Supported pause frame use: Symmetric
<span style...
AlHill
Are the two of you related?
Stay with only one thread.
Doc
Muthurajan_J_Intel
Thank you very much.
Yes you are correct.
Both are related.
Can I please request for guidance on this issue please
Thank you very much
HI Mjay,
Thank you for the confirmation. Can you clarify below information?
1) What is the brand and model of the system where the I210 is embedded on?
2) What is this i354 connected thru external PHY? Is this a separate standalone quad port NIC? Please provide the link about this device.
3) As mentioned by you this issue is seen with linux kernel (ubuntu 14.04), did you encounter the same issue if using other OS?
Sharon T
Hi Mjay,
Please feel free to provide the information requested.
Sharon T
