Ethernet Products
All support for Intel NUC 7 - 13 systems has transitioned to ASUS. Read latest update.
4755 Discussions
What would cause my network card to keep repeatedly show discards and errors? On a regular basis if I run "netstat -e" there are discards and errors. Would an old driver cause this issue?
Jjohn101
I have changed network cable and port.
It happens to more than one pc running the same OS and drivers. Other pcs are on different network/VLAN.
OS:Windows 7 pro sp1
Intel I218-LM
Current Driver date: 7/26/2016
Driver version: 12.15.23.7
Mike_Intel
Hello Jjohn101, It is really hard to pinpoint the exact root cause of the issue since the NIC is on-board. When a NIC is on-board, it is using the system resources like the RAM and processor. What we can do is provide recommendations to possible fix the issue. And just to add, different board manufacturer have different implementation on how the use on-board NIC and some of them even modify the NIC cards. As for my recommendation, you may try updating the driver since our latest generic driver is version 23.5.2 https://downloadcenter.intel.com/product/71307/Intel-Ethernet-Connection-I218-LM If you have questions, please let us know. Best regards, Michael L. Intel Customer Support Under Contract to Intel Corporation
Mike_Intel
Hello Jjohn101, Thank you for posting in Intel Ethernet Communities. It is hard to tell the possible cause of the issue. You may need to perform further test and a lot of observation to identify the cause. For me to provide some recommendations that may prevent the issue from happening again, please provide the following details. 1. Are you using an on-board NIC? 2. Is it happening before? 3. What steps have you tried so far to fix the issue? If you have questions, please let us know. Best regards, Michael L. Intel Customer Support Under Contract to Intel Corporation
Jjohn101
Yes, onboard NIC.
Yes, happens frequently.
Noticed latency on a few workstations , each time the NIC found with a large number of discards and errors.
Originally rebooted workstations to resolve issue before spotting errors on NIC. Found that running the INTEL diagnostics fixes latency issue, reboot not required. Passes on all diagnostics - Connection, Cable and hardware. Will need solid proof on root cause because of rigid change control process, nothing else changed/modified.
Mike_Intel
Mike_Intel
Hello Jjohn101, Just want to check if you tried updating the driver using the link that I provided. If you have questions, please let us know. Best regards, Michael L. Intel Customer Support Under Contract to Intel Corporation
