Where can I find a map of registers Ethernet Switch FM4112?
Hi microelectron.ru,
Thank you for contacting Intel.
For your inquiry regarding Intel® Ethernet Switch, you may submit your enquiry thru online web form http://www.intel.com/p/en_US/support/contactsupport Contact Support.
Have a great day!
Sincerely,
Sandy
I'm not an expert on this product, but I noticed that there is at least one mapping table (section 4.4) in the https://www-ssl.intel.com/content/www/us/en/switch-silicon/ethernet-switch-fm4000-datasheet.html Intel® Ethernet Switch FM4000: Datasheet. Is this what you need?
Mark
it is not the
ethernet-switch-fm2112-datasheet.pdf (section 5.2) Register Map
ethernet-switch-fm4000-datasheet.pdf not section of Register Map
Please contact our business link support with regards to the missing Register Map information on the ethernet-switch-fm4000-datasheet.pdf.
You may find the contact details below: https://kaveri.intel.com/ibl/help/support.htm# telephone Intel Business Link {Support}
Sincerely,
Sandy
Hi, please refer to https://embedded.communities.intel.com/thread/7912?sr=inbox&ru=931380 Where can I find a map of registers Ethernet Sw... | Embedded Community. Thanks! LynnZ.
