Ethernet Products
5743 Discussions
Why LnkSta and LnkCtl show different with X710?
JMa11
My lspci -vvv output for the X710DA4 Ethernet Adapter shows LnkSta to be 8GT/s but LnkCtl is 2.5GT/s.
Motherboard used is the S2600CW with dual E5-2697Av4 CPU.
Thanks....
Hi JacksonM,
Thank you for posting your query in Wired Ethernet Communities.
X710-DA4 should work according to specs which is PCI-E Gen 3 x8 (8GT/s), as to why the LnkCtl shows 2.5GT/s. Kindly share additional information below for us to further investigate.
1. ethtool - i output to show the driver version and firmware version of your X710-DA4
2. BIOS and FW version of your S2600CW
3. Have you tried to install the X710-DA4 on other PCI-E Gen 3 x8 or x16 slots?
4. Have you tried installing other PCI-E Gen3 x8 on the same slot on where the X710-DA4 was installed?
Vince
JMa11
Thanks, Vince. I captured a few more output for you to see.
The driver loaded is the i40e.
DPDK output: PMD:
eth_i40e_dev_init(): FW5.0 API 1.5 NVM 05.00.04 eetrack 800024cd
(But we have also disabled the DPDK and put driver to kernel. Output from below is without DPDK).
Yes, we have tried plugging into other slots as well.
Motherboard BIOS (Note: I am using the S2600CO board here. And also upgraded my BIOS for the board. The same results with Cottonwood Pass board)
SE5C600.86B.02.06.0005.080320162159
Ethtool -I output
driver: i40e
version: 1.5.16
firmware-version: 5.04 0x800024cd 0.0.0
bus-info: 0000:04:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
Here's the lspci output (LnkSta and LnkCtl2)
LnkSta: Speed 8GT/s, Width x8, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR-, OBFF Not Supported
DevCtl2: Completion Timeout: 4s to 13s, TimeoutDis-, LTR-, OBFF Disabled
LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
Kernel driver in use: i40e
d0: 01 00 1e 00 00 00 00 00 00 00 00 00 00 00 00 00
It seems that the motherboard and X710 card cannot negotiate the speed. On another system (Advantech motherboard), where I was able to see 8GT/s on LnkCtl2, the first byte of the d0 register is 03.
Hope it is clear. Let me know if you need more details.
Appreciate your help
Jackson
Hi Jackson, thanks for sharing the information, i'm currently checking your concern and will update this thread as soon as possible.
regards,
Vince
JMa11
Hi, Just a bit more info to update:
I have another system (Advantech ASMB-913) which came up with the Gen3 on LnkCtl2. It's the same Ubuntu OS, same batch of 10G NIC (though not the exact same X710 card).
Any leads?
Jackson
Hi Jackson,
Thanks for the additional details, we're still investigating your issue. Please share which PCIe slot the X710 was installed on S2600CO.
Vince
JMa11
Hi, Vince:
On the S2600CO, it was connected to Slot 5 on the motherboard.
Jackson
Thanks Jackson, have you tried connecting to other slots such as slot 4 for further isolation? are there other add-in cards installed on the S2600CO?
regards,
Vince
JMa11
Yes, Vince, I have installed the X710 card on other slots as well. It was the only card I plugged into the system.
Thanks Jackson, have you tried to install one of the supported PCIe* Gen 3 add-in adapters mentioned in the site below to further isolate the issue?
http://www.intel.com/content/www/us/en/support/boards-and-kits/000007457.html
Under your system's BIOS, Advanced, Processor Configuration, the processor has label of "V1" or "V2"? Example - E52640 V2 @ 2.00GHz
Vince
JMa11
Thanks for the reply, Vince.
No, I was not aware of this list of PCI-e peripherals.
The processors are the v4 Type. It's the E5-2697Av4 with S2600CW-R motherboard. Since the X710DA4 card is also from Intel, I just assume all will come up as Gen3 without issue. They should work as advertised...
Also, I have plugged in a Coletto Creek (Intel 8950 QAT) card and it showed up on lspci as Gen2 (5.0GT/s). Again, it was detected as Gen3 x16.
This leads me to think maybe it's a motherboard problem? How does the motherboard affect the speed of the PCIe?
Jackson
JMa11
Here's the Coleto Creek output: (Sorry about the misspell earlier)
83:00.0 Co-processor: Intel Corporation Coleto Creek PCIe Endpoint
Subsystem: Intel Corporation Device 35c8
Physical Slot: 0-1
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- SERR-
Latency: 0
Interrupt: pin A routed to IRQ 10
Region 0: Memory at 38007fe00000 (64-bit, prefetchable) [size=512K]
Region 2: Memory at c8000000 (64-bit, non-prefetchable) [size=256K]
Region 4: Memory at c8040000 (64-bit, non-prefetchable) [size=256K]
Capabilities: [b0] MSI: Enable- Count=1/1 Maskable+ 64bit+
Address: 0000000000000000 Data: 0000
Masking: 00000000 Pending: 00000000
Capabilities: [60] MSI-X: Enable- Count=33 Masked-
Vector table: BAR=2 offset=0003b000
PBA: BAR=2 offset=0003b800
Capabilities: [6c] Power Management version 3
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [74] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <128ns, L1 <1us
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+
DevCtl: Report errors: Correctable- Non-Fatal+ Fatal+ Unsupported-
RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+ FLReset-
MaxPayload 256 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq+ AuxPwr- TransPend-
LnkCap: Port # 0, Speed 5GT/s, Width x16, ASPM L0s, Exit Latency L0s <512ns, L1 unlimited
ClockPM- Surprise- LLActRep- BwNot-
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 5GT/s, Width x16, TrErr- Train- SlotClk- DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range B, TimeoutDis+, LTR-, OBFF Not Supported
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Thanks Jackson, kindly confirm if I've captured the correct details from your testing.
1. S2600CO and X710 - LnkSta = 8GT/s, LnkCtl2 = 2.5GT/s
2. S2600CW and X710 - LnkSta = 8GT/s, LnkCtl2 = 2.5GT/s
3. S2600CW and QAT 8950 - LnkSta = 5GT/s, LnkCtl2 = 5GT/s
4. Advantech ASMB-913 and X710 - LnkSta = 8GT/s, LnkCtl2 = 8GT/s
regards,
Vince
JMa11
Hi, Vince:
Yes, you have captured the details perfectly.
Jackson
JMa11
Hi, Vince:
Just to keep updated, I have the PCIe Parameters on the setup page set to both and . Neither change how the "lspci" reports the state.
JMa11
Hi, Vince:
Seems like we may have an answer (or a closing to one).The Link Status Register (LnkSta) is the indication of the negotiated speed. While the Link Control Register is not directly related.
Thanks...
Hi Jackson, we've also confirmed from our end that the link control register does not represent the speed of the link.
Please let us know if you still have other assistance needed.
regards,
Vince
JMa11
